How to Extend start/end point of curve (wall location) API C# ?
I am trying to shift/extend the End and Start point of a curve.
I get that curve from the wall.Location command.
In fact, I am currently transferring a program made on dynamo to External command with API Revit to integrate it in a plugin.
So, here's the question : Is there a function that allows me to do the equivalent of the Curve.ExtendStart or Curve.ExtendEnd node with the revit API in C #? If not, can you help me find a way to do something similar?
I want an offset on my End/Start point equal to half the witdth of the wall from wich I get the curve.
So, here is what I did so far with my code (don't mind the french):
foreach(Wall wall1 in WallList)
Double Width = wall1.Width;
Double ExtendDistance = Width / 2;
TaskDialog.Show("Info", "La largeur du voile est : " + Width+" et la largeur divisé par deux est de : "+ExtendDistance);
LocationCurve locationCurve = wall1.Location as LocationCurve;
Curve wallCurve = locationCurve.Curve as Curve;
//Insert Code (Extend end/start point of curve)
My goal is to automatically place a stiffener at the end/start of each wall.
To do this, I need a point. I already know how to place and contrain a stiffener from a placement point.
My concern is how to find said placement point.
Can you help me please,
I'm french please excuse the mistakes and clumsiness.
Cheers, Samuel
jeremytammik
This question was recently discussed right here in the forum.
Please always search for existing answers before raising a new one. That will save a tremendous amount of time, both for you yourself and the rest of the universe. Thank you!
Here is the blog post summarising the results:
https://thebuildingcoder.typepad.com/blog/2020/02/adjusting-wall-location-curve-and-visual-presentat...
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thank you for your answer!
Ah yes, sorry about that, I am familiar with your blog, but I must have missed this page. I do think I found what I was looking for in your link, thanks a lot.
Best
