how to download .svf file !!
I have uploaded .rvt file and by using the API's. also i can view the the object by using the viewers
now i need to download .svf so i can render the view anytime without calling the apis.
is there any possible way to download svf file
jeremytammik
You do not say much about how or where you uploaded, or what you are talking about, so you leave it up to your readers to guess a lot of context.
Since you mention SVF, I assume that you are talking about a Forge application.
In that case, you should probably direct your question to the Forge help on StackOverflow:
https://forge.autodesk.com/en/support/get-help
Please note that this discussion forum is dedicated to programming Revit on the desktop using the Revit API.
On the other hand, re-reading your question, I notice that this issue has been frequently discussed in the past.
Therefore, a simple Internet search will probably also give you all the information you need, for instance, searching for something like "autodesk forge download svf":
https://duckduckgo.com/?q=autodesk+forge+download+svf
I hope this helps.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
