How to Disregard Pipes that are Vertical
aciavardini
aciavardini
I currently have a FilteredElementCollector finding all pipes in the model. I would like to disregarded pipes that are vertical/have a slope equal to "Not Computed". What is the best way to achieve this?
public Result Execute(ExternalCommandData edata, ref string message, ElementSet elements)
            UIDocument uidoc = edata.Application.ActiveUIDocument;
            Document doc = uidoc.Document;
            Transaction t = new Transaction(doc, "Auto Trench");
            t.Start();
            // Find all Pipes in Model
            FilteredElementCollector pipes = new FilteredElementCollector(uidoc.Document);
            List<Pipe> pipeList = pipes.OfClass(typeof(Pipe)).OfType<Pipe>().ToList();
Thanks.
Moustafa_K
All pipes are driven from a Linework. if you extracted the line from the pipe and checked its Z direction against 1, then you will be able to filter that out ... see the below code if does help
foreach (Pipe pipe in pipeList)
    var pipeCurve = pipe.Location as LocationCurve;
    var pipeLine = pipeCurve.Curve as Line;
    if (pipeLine.Direction.Z == 1) continue;
    //do my stuff to not 100% vertical Pipes
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
jeremy_tammik
Thanks to Mostafa for one initial approach.
If you choose to follow that suggestion, I would definitely add some fuzz, i.e., compare the Z direction to be almost equal to 1.0, not exactly equal.
https://thebuildingcoder.typepad.com/blog/2022/08/instances-in-room-and-need-for-fuzz.html#3
This kind of comparison requires post-processing of the filtered element collector results.
If you can check the verticality or the slope not computed property up front using existing properties or parameters on the pipe elements, you might be able to replace the post-processing by significantly faster quick or slow filters:
http://thebuildingcoder.typepad.com/blog/2015/12/quick-slow-and-linq-element-filtering.html
However, depending on your requirements, the post-processing might be perfectly acceptable, and it is probably the easiest approach.
rtg.dev015A9H9
Hi @aciavardini ,
This is another approach, maybe more performant:
Parameter slopeParam = pipe.get_Parameter(BuiltInParameter.RBS_PIPE_SLOPE);
if (slopeParam.HasValue)
	//Do something
else
	//Do another thing on pipes with parameter slope "Not Computed"
 I did a few tests and it appears that "Not computed" pipes always have this parameter property set to false.
@aciavardini
