How to determine if the matrix contains rotation?
Message 1 of 12
Transform does not seem to have this property defined.
Replies (11)
Message 2 of 12
jeremy_tammik
I would suggest searching for an answer in a more generic forum, e.g., StackOverflow:
https://stackoverflow.com/search?q=determine+matrix+rotation
Message 3 of 12
KM_Yotsuha
when rotation only happens in xy plan,If the transform's BasisX is not  of same direction of XYZ.BasisX,then it is rotated. you can even computer the rotate angle,it is same as the angle between BasisX of local and globle coordinate~~
in 3d spaces,compare all basis~~
Message 4 of 12
It's not rigorous. I considered this approach a long time ago and have been thinking about it again recently. As a simple example, the scaling matrix and the mirror matrix may BaseX, BaseY, BaseZ may all change. So I say we should provide a property to determine that. So basically it is very difficult to determine because it is likely to be a composite matrix and difficult to infer.
Message 5 of 12
jeremy_tammik
This is actually a quite common task in computer graphics. Search for the term 'matrix decomposition':
https://duckduckgo.com/?q=matrix+decomposition
The Building Coder discussed it in 2009:
https://thebuildingcoder.typepad.com/blog/2009/05/transform-an-element.html
Message 6 of 12
mhannonQ65N2
Of the top of my head, to determine if the matrix has rotation vs just reflection you could still compare the basis vectors like @KM_Yotsuha suggested but you should check if the matrix's basis vectors are in the same or opposite direction. One way of doing this is to check if the matrix's basis vector is a scalar multiple of the standard basis vector, by ensuring that only one of its components (for basis x, check the x component, etc.) is non-zero. You can also check if it has a reflection by using the HasReflection property.  Alternatively, if you want to check if it is just a rotation and possibly a translation, you can check if it's determinant is equal to one as all rotation matrices have a determinant of one (note that the identity matrix also has a determinant of one and is technically considered a rotation matrix).
(Note: Make sure to take floating-point precision into account, instead of checking if something is zero, check if its absolute value is less than or equal to Revit's precision value, which is 1e-9 if I recall correctly)
Message 7 of 12
ricaun
The Transform class has the method AlmostEqual to compare two transforms with a tolerance 1e-9.
Could be used to compare only the Rotation matrix if the Scale and the Origin are removed.
Some methods like this:
/// <summary>
/// Determines whether this transformation and the specified transformation are the
/// same rotation within the tolerance (1.0e-09).
/// </summary>
/// <param name="left">The first transformation.</param>
/// <param name="right">The second transformation.</param>
/// <returns>True if the two transformations rotation are equal; otherwise, false.</returns>
public bool AlmostEqualRotation(Transform left, Transform right)
    var tLeft = left.ScaleBasis(1 / left.Scale);
    var tRight = right.ScaleBasis(1 / right.Scale);
    tLeft.Origin = XYZ.Zero;
    tRight.Origin = XYZ.Zero;
    return tLeft.AlmostEqual(tRight);
And here are some tests to validate the method:
Debug.Assert(AlmostEqualRotation(Transform.Identity, Transform.Identity), "Identity");
Debug.Assert(AlmostEqualRotation(Transform.Identity, Transform.CreateTranslation(XYZ.BasisX)), "CreateTranslation");
Debug.Assert(AlmostEqualRotation(Transform.Identity, Transform.CreateRotation(XYZ.BasisZ, 0)), "CreateRotation");
Debug.Assert(AlmostEqualRotation(Transform.Identity, Transform.Identity.ScaleBasis(2)), "ScaleBasis");
Debug.Assert(!AlmostEqualRotation(Transform.Identity, Transform.CreateRotation(XYZ.BasisZ, 1)), "!CreateRotation");
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 8 of 12
Maybe it should be the following code, but I don't seem to be reading too much into it. Not very good at math, not sure how to tell which ones are contained after the composite matrix is split.
https://github.com/accord-net/framework/wiki/Mathematics
// Singular value decomposition
    SingularValueDecomposition svd = new SingularValueDecomposition(A);
    var U = svd.LeftSingularVectors;
    var S = svd.Diagonal;
    var V = svd.RightSingularVectors;
// or (please see documentation for details)
    SingularValueDecomposition svd = new SingularValueDecomposition(A.Transpose());
    var U = svd.RightSingularVectors;
    var V = svd.LeftSingularVectors;
// Eigenvalue decomposition
    EigenvalueDecomposition eig = new EigenvalueDecomposition(A);
    var V = eig.Eigenvectors;
    var D = eig.DiagonalMatrix;
// QR decomposition
    QrDecomposition qr = new QrDecomposition(A);
    var Q = qr.OrthogonalFactor;
    var R = qr.UpperTriangularFactor;
// Cholesky decomposition
    CholeskyDecomposition chol = new CholeskyDecomposition(A);
    var R = chol.LeftTriangularFactor;
// LU decomposition
    LuDecomposition lu = new LuDecomposition(A);
    var L = lu.LowerTriangularFactor;
    var U = lu.UpperTriangularFactor;
Message 9 of 12
mhannonQ65N2
I don't think that those decompositions will be of much use to you. Though perhaps with the QR decomposition, you could check if the orthogonal factor has a determinant of 1; if so, it is a rotation matrix and I think your original matrix contains a rotation. But I'm not too sure this will work and you'd have to convert Revit's Transform into an Accord.net matrix.
I'd recommend just sticking to comparing the basis vectors. Here's an example:
const double p = 1e-9;
Transform t;
var isScaleX = Math.Abs(t.BasisX.X) > p && Math.Abs(t.BasisX.Y) < p && Math.Abs(t.BasisX.Z) < p;
var isScaleY = Math.Abs(t.BasisY.X) < p && Math.Abs(t.BasisY.Y) > p && Math.Abs(t.BasisY.Z) < p;
var isScaleZ = Math.Abs(t.BasisZ.X) < p && Math.Abs(t.BasisZ.Y) < Z && Math.Abs(t.BasisZ.Z) > p;
var isRotation = !(isScaleX && isScaleY && isScaleZ);
This should be sufficient unless you are working with some transformation I wouldn't expect to find in Revit like a shear mapping.
Message 10 of 12
The composite matrix is obviously not very suitable for judging with it.
Message 11 of 12
Message 12 of 12
The main reason for discussing this issue is that the API does not provide this property or method.
