How to create Z-offset Extrusion via API
YaGitHub
YaGitHub
Hi, kinds!
I wanna make a function for creating Extrusion easily like that:
Extrusion createExtrusionZ(CurveArrArray pProfile, double bottom, double height)
            // mm to feet
            double bottomF = mmToFeet(bottom);
            double heightF = mmToFeet(height);
            // create Sketch Plane
            Plane pPlane = Plane.CreateByNormalAndOrigin(new XYZ(0.0,0.0,1.0),new XYZ(0.0,0.0,bottomF));
            SketchPlane pSketchPlane = SketchPlane.Create(_rvtDoc, pPlane) as SketchPlane;
            // return new Extrusion
            bool bIsSolid = true;
            return _rvtDoc.FamilyCreate.NewExtrusion(bIsSolid, pProfile, pSketchPlane, heightF);
I expect that extrusion from [bottom] to [bottom + height] at Z direction, but I get that from [0] to [height] always.
I suspect that the way to create SketchPlane is mistaken, but I don't have any certain idea.
Could you give me a hand, gentles?
RPTHOMAS108
Try putting your start Z values into the points in your profile.
YaGitHub
Thank you, Sir.
I could understand the specification of NewExtrusion-function.
But I wanna make a function as I posted. Therefore I did like below:
            // mmToFeet
            // make sketch plane
            Plane pPlane = Plane.CreateByNormalAndOrigin(new XYZ(0.0,0.0,1.0),new XYZ(0.0,0.0,0.0));
            // make Extrusion
            Extrusion newExtrusion = _rvtDoc.FamilyCreate.NewExtrusion(bIsSolid, pProfile, pSketchPlane, heightF);
            // move Extrusion
            XYZ transPoint = new XYZ(0.0, 0.0, bottomF);
            ElementTransformUtils.MoveElement(_rvtDoc, newExtrusion.Id, transPoint);
            return newExtrusion;
Step 1 : Make new Extrusion attached to Z=0
Step 2 : Move the Extrusion to expected Z
RPTHOMAS108
Intuitively it would seem that the plane would set the z value as you had it but apparently not.
I don't know if there is a better option than moving the item after creation to enable you to have the same form of function. Curves in the profile can be iterated and transformed to new Z but I don't know if that would be advantageous or not.
