How to Create Line based on Angle
I have element line location in Revit code (first line).
Then i need to add second line.
The second line start point is any point on the line which is 90 degrees from the first line on X/Y Axis.
I cant get method to create second line based on angle.
Below is the example of the line i need.
I have been playing around with method CreateTransformed, CreateRotationAtPoint and CrossProduct but i still don't get the result i want.
Thanks.
aignatovich
Hi! It is simple, just get a) line direction b) line sketch plane normal
Then normal.CrossProduct(direction) should be your second line direction or, may be, you need -1*normal.CrossProduct(direction)
Take any point on first line, for example, pt1 = fistLine.Evaluate(0.5, true), pt2 = pt1 + length * direction, then create the second line Line.CreateBound(pt1, pt2), then create model curve on the first line sketch plane, base on this second line
Thanks a lot Ignatovich.
Here is my code based on your solution:
Line line1 = Line.CreateBound(XYZ.Zero, new XYZ(10, 10, 10));
XYZ pntCenter = line1.Evaluate(0.5, true);
XYZ normal = line1.Direction.Normalize();
XYZ dir = new XYZ(0, 0, 1);
XYZ cross = normal.CrossProduct(dir);
XYZ pntEnd = pntCenter + cross.Multiply(10);
Line line2 = Line.CreateBound(pntCenter, pntEnd);
Debug.Print("line1: " + line1.Direction.ToString());
Debug.Print("line2: " + line2.Direction.ToString());
Debug.Print("line1: Start " + line1.GetEndPoint(0).ToString() + " End " + line1.GetEndPoint(1).ToString());
Debug.Print("line2: Start " + line2.GetEndPoint(0).ToString() + " End " + line2.GetEndPoint(1).ToString());
Smiley Very Happy
strsuraj
Hi, @aignatovich how about creating a reference plane at a particular angle say 33 degrees. Do we have a direct method, where we can pass desired angle as an argument.
joldman473
Hi  @aignatovich,
Can you please show me how to get the  line sketch plane normal:
when I create it a plane by a normal ( my line direction) and an origin line origin.
The cross product plane.Normal(line.Direction) Will be equal to (0,0,0) because the two vectors have the same direction.
Thanks in advance.
aignatovich
sketchPlane.GetPlane().Normal
