how to create beams by lines from dwg linked into revit
27925916
Message 1 of 27
27925916
I link the dwg by the tool of revit  below:
and we can see it  below, and I wanna know how to use the API to create beams by the lines standing for beam in dwg?
what should I do ?  should I use the API to select lines representing beams first ? and what to do next ..
Replies (26)
Message 21 of 27
matthew_taylor
Hi @27925916,
Riiiiight. You can get everything but text.
There are 3 methods of doing this that come to mind.
  1. As Jeremy suggested in your other post, use AutoCAD (via Revit) to get the information you need.
  2. Do pre-processing in AutoCAD (either from Revit or independently). (Just put the beam lines on a layer called 'BeamType1', 'BeamType2' etc. This negates the need to find the text in Revit.)
  3. Explode non-linked importInstances, get the information you need, undo that command.
3 is the easiest to do manually, but there's no access to the 'explode' part via the API.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Message 22 of 27
27925916
if I choose first way ,when I pick a note containning text in revit , then how I get its information  by exploring the internals of a DWG?  the GraphicsStyleId in revit can have relationship with the internals of a DWG?
And I should use the dll of ObjectARX?
Message 23 of 27
matthew_taylor
You would need to get all relevant information from the DWG by actually opening the DWG in AutoCAD (or by using RealDWG). There is a separate forum for AutoCAD API or ObjectARX.
You would also need to perform a transformation of the DWG point data as you bring it into Revit if the ImportInstance has been moved/rotated from origin.
Cheers,
-Matt
Message 24 of 27
27925916
is there any link to a free trial of RealDwg? I am just a student.. Smiley Embarassed
Message 25 of 27
matthew_taylor
Point 7 seems to cover that:
http://techsoft3d.com/developers/technical-documentation/autodesk-realdwg/
See the link also to AutoCAD free 30-day trial.
Cheers,
-Matt
Message 26 of 27
27925916
a good people advises me a way that we can make  add-inexport to a DXF file and then read the text from that, is it ok?
Message 27 of 27
matthew_taylor
That would work.
There's probably examples of parsing DXF files out there. Can't imagine it's much fun though. Smiley Wink
Cheers,
-Matt
