how to create a wall extending to roof by API ?
27925916
27925916
how to create a wall extending to the roof by API ? and how to get the roof which a wall is extending to?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @27925916 ,
1)how to create a wall extending to the roof by API?
Ans: Have a look at this below link
https://forums.autodesk.com/t5/revit-api-forum/wall-attach-top-base-no-api/m-p/5992539
2)how to get the roof to which a wall is extending?
https://forums.autodesk.com/t5/revit-api-forum/is-it-possible-get-all-elements-ids-witch-connected-t...
By using this code you can get all the elements connected to a particular wall. After getting all the elements connected to a particular wall you can get the roof element from them.
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
