How to create a SwitchSystem in Revit API?
mourajrn
mourajrn
Hello, everyone,
I want to connect OST_LightingFixtures with OST_LightingDevices but I couldn't find a method for creating the system.
How can I create a SwitchSystem in Revit API using C#?
Thank you in advance.
ricaun
You couldn't find it because there is no method to create a SwitchSystem using the Revit API.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
mourajrn
Thanks for the reply, Luiz.
I always watch your videos on YouTube. Congratulations on the content.
Is there any workaround for creating SwitchSystems? Or is it really impossible?
ricaun
I tried PostableCommand but does not work, the only way I found is by clicking on the Switch button on the Create Systems ribbon using System.Windows.Automation.
I did the same in Power to force open the Voltage/PhaseNumber UI selection.
I implemented the plugin ElectricalUtils to add a shortcut to make it easy to create circuits inside the shared family.
[video]
The only problem is that the plugin needs to wait for the Revit UI and then I could click on the button using Windows Automation, to wait for a DocumentChanged to get the Switch...
Everything works in an async way, which is kinda hard work...
Still waiting for Autodesk to add something like:
var switchSystem = MEPSystem.CreateSwitch(document, elements);
