I tried to create a floor with openings.
Instead of creating an opening(used by doc.Create.NewOpening method) when creating a floor,
I want to create a floor with an opening only with a curve through a 'profile'.
I tried to create it with below code,
The creation fails with the error 'The curves do not form a closed contiguous loop'.
Is there a separate order in which the outer curve and the opening curve should be added to the CurveArray?
Or are there other rules?
I wonder if there is a way to create a floor with an opening without using doc.Create.NewOpening method.
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
var uiApp = commandData.Application;
var uiDoc = uiApp.ActiveUIDocument;
var doc = uiDoc.Document;
var pts = new XYZ[]
new XYZ(0, 400, 0),
new XYZ(400, 400, 0),
new XYZ(400, 0 ,0),
new XYZ(0, 0, 0)
var openingPts = new XYZ[]
new XYZ(100, 300, 0),
new XYZ(300, 300, 0),
new XYZ(300, 100 ,0),
new XYZ(100, 100, 0)
Curve curve = null;
var curves = new CurveArray();
curves.Append(Line.CreateBound(pts[1], pts[0]));
curves.Append(Line.CreateBound(pts[0], pts[3]));
curves.Append(Line.CreateBound(pts[3], pts[2]));
curves.Append(Line.CreateBound(pts[2], pts[1]));
curves.Append(Line.CreateBound(openingPts[3], openingPts[2]));
curves.Append(Line.CreateBound(openingPts[2], openingPts[1]));
curves.Append(Line.CreateBound(openingPts[1], openingPts[0]));
curves.Append(Line.CreateBound(openingPts[0], openingPts[3]));
using (var tr = new Transaction(doc, "Starting Floor Create"))
try
tr.Start();
doc.Create.NewFloor(curves, false);
tr.Commit();
catch (Exception ex)
throw ex;
return Result.Succeeded;
Here is one discussion from 2013 that discusses a similar issue and indicates that it was not so easy to achieve back then:
That is a long time ago, though, so things may have changed since.
Here is the explanation of the new floor creation API:
I am pretty sure that the IList<CurveLoop> profile argument enables creation of a floor with holes.
Maybe you do need to revert the negative hole area loop orientations, just as you suggest.
Have you searched the Revit SDK samples for Floor.Create? I did, and see 26 matches across 6 files. Maybe one of them will help?
Please let us know how you end up solving this.
Thank you!
