I use ReferenceIntersector in my plugin,and use flowing codes to generate 3d View for ReferenceIntersector:
if user set view template for 3d view, then the view created may not show every model element.
how can i create a 3d view in which every model element is visible?
Solved by RPTHOMAS108. Go to Solution.
Duplicate the type object set type parameter to none (DEFAULT_VIEW_TEMPLATE=New ElementId(0)) and use the new type in the create method
I get the 0 value from RevitLookup I expected it to be -1 for none (InvalidElementId).
Does that work?
Regarding ReferenceIntersector less is more: if you know the specific elements you are trying to find intersections with or their categories then those should be isolated to improve performance.
Does that work?
