I am not really sure why some of my posts don't stick around, but I had an interest in this post and so I think this is a solution to the issue, with maybe a little extra.
- Select the rooms to move
- Select the level to move them too
- Press OK
- Store the Room Location Point
- Unplace the Room
- Use a Failure Handler to bypass the "Unplace room in model" warning
- Get the Plan Topology for the level selected
- Find an empty circuit in the Topology
- There has to be at least one empty circuit (Room)
- Replace the room
- Move the room to the location it was in on the other level
Here is the command code:
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB;
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace MyApp.Testing
public partial class TestForm : System.Windows.Forms.Form
Document doc;
public TestForm(Document _doc)
InitializeComponent();
doc = _doc;
private void btnClose_Click(object sender, EventArgs e)
Close();
private void TestForm_Load(object sender, EventArgs e)
foreach (Room room in Helpers.Collectors.ByCategory(doc, BuiltInCategory.OST_Rooms))
if (room.Area > 0 && room.Location != null)
ListViewItem item = listView1.Items.Add(room.Number + " - " + room.Name);
item.Tag = room;
SortedList<string, Level> levels = new SortedList<string, Level>();
foreach (Level level in Helpers.Collectors.ByCategoryNotElementType(doc, BuiltInCategory.OST_Levels))
levels.Add(level.Name, level);
cboLevel.DataSource = levels.ToList();
cboLevel.DisplayMember = "Key";
cboLevel.ValueMember = "Value";
private void btmOK_Click(object sender, EventArgs e)
try
using (TransactionGroup transGroup = new TransactionGroup(doc))
transGroup.Start("Move Rooms");
foreach (ListViewItem item in listView1.CheckedItems)
Room room = (Room)item.Tag;
LocationPoint rmPT = room.Location as LocationPoint;
XYZ roomPoint = rmPT.Point;
double offset = room.LimitOffset;
using (Transaction trans1 = new Transaction(doc))
trans1.Start("Unplace Room");
FailureHandlingOptions failOptions = trans1.GetFailureHandlingOptions();
failOptions.SetFailuresPreprocessor(new UnplacedRoomWarning());
trans1.SetFailureHandlingOptions(failOptions);
room.Unplace();
trans1.Commit();
using (Transaction trans2 = new Transaction(doc))
trans2.Start("New Room");
Level level = (Level)cboLevel.SelectedValue;
PlanTopology topo = doc.get_PlanTopology(level);
PlanCircuitSet circuits = topo.Circuits;
foreach (PlanCircuit circuit in circuits)
if (!circuit.IsRoomLocated)
Room newRoom = doc.Create.NewRoom(room, circuit);
newRoom.get_Parameter(BuiltInParameter.ROOM_UPPER_LEVEL).Set(level.Id);
newRoom.LimitOffset = offset;
XYZ move = new XYZ(roomPoint.X - rmPT.Point.X, roomPoint.Y - rmPT.Point.Y, rmPT.Point.Z);
ElementTransformUtils.MoveElement(doc, newRoom.Id, move);
break;
trans2.Commit();
transGroup.Assimilate();
Close();
catch (Exception ex)
MessageBox.Show(ex.ToString());
public class UnplacedRoomWarning : IFailuresPreprocessor
public FailureProcessingResult PreprocessFailures(FailuresAccessor failuresAccessor)
IList<FailureMessageAccessor> failures = new List<FailureMessageAccessor>();
failures = failuresAccessor.GetFailureMessages();
foreach (FailureMessageAccessor failure in failures)
if (failure.GetSeverity() == FailureSeverity.Warning)
if (failure.GetFailureDefinitionId() == BuiltInFailures.RoomFailures.RoomUnplaceWarning || failure.GetFailureDefinitionId() == BuiltInFailures.RoomFailures.RoomHeightNegative)
failuresAccessor.DeleteWarning(failure);
else
failuresAccessor.ResolveFailure(failure);
return FailureProcessingResult.ProceedWithCommit;
return FailureProcessingResult.Continue;
Simple Win Form Layout:
Here is the Win Form designer code:
/// <summary>
/// Required designer variable.
/// </summary>
private System.ComponentModel.IContainer components = null;
/// <summary>
/// Clean up any resources being used.
/// </summary>
/// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
protected override void Dispose(bool disposing)
if (disposing && (components != null))
components.Dispose();
base.Dispose(disposing);
#region Windows Form Designer generated code
/// <summary>
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
/// </summary>
private void InitializeComponent()
this.btnClose = new System.Windows.Forms.Button();
this.btmOK = new System.Windows.Forms.Button();
this.listView1 = new System.Windows.Forms.ListView();
this.columnHeader3 = ((System.Windows.Forms.ColumnHeader)(new System.Windows.Forms.ColumnHeader()));
this.cboLevel = new System.Windows.Forms.ComboBox();
this.label1 = new System.Windows.Forms.Label();
this.label2 = new System.Windows.Forms.Label();
this.SuspendLayout();
// btnClose
this.btnClose.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
this.btnClose.Location = new System.Drawing.Point(216, 526);
this.btnClose.Name = "btnClose";
this.btnClose.Size = new System.Drawing.Size(75, 23);
this.btnClose.TabIndex = 0;
this.btnClose.Text = "Close";
this.btnClose.UseVisualStyleBackColor = true;
this.btnClose.Click += new System.EventHandler(this.btnClose_Click);
// btmOK
this.btmOK.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
this.btmOK.Location = new System.Drawing.Point(297, 526);
this.btmOK.Name = "btmOK";
this.btmOK.Size = new System.Drawing.Size(75, 23);
this.btmOK.TabIndex = 1;
this.btmOK.Text = "OK";
this.btmOK.UseVisualStyleBackColor = true;
this.btmOK.Click += new System.EventHandler(this.btmOK_Click);
// listView1
this.listView1.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
| System.Windows.Forms.AnchorStyles.Left)
this.listView1.CheckBoxes = true;
this.listView1.Columns.AddRange(new System.Windows.Forms.ColumnHeader[] {
this.columnHeader3});
this.listView1.FullRowSelect = true;
this.listView1.HeaderStyle = System.Windows.Forms.ColumnHeaderStyle.None;
this.listView1.HideSelection = false;
this.listView1.Location = new System.Drawing.Point(12, 27);
this.listView1.Margin = new System.Windows.Forms.Padding(3, 5, 3, 5);
this.listView1.Name = "listView1";
this.listView1.Size = new System.Drawing.Size(360, 464);
this.listView1.Sorting = System.Windows.Forms.SortOrder.Ascending;
this.listView1.TabIndex = 2;
this.listView1.UseCompatibleStateImageBehavior = false;
this.listView1.View = System.Windows.Forms.View.Details;
// columnHeader3
this.columnHeader3.Text = "";
this.columnHeader3.Width = 350;
// cboLevel
this.cboLevel.FormattingEnabled = true;
this.cboLevel.Location = new System.Drawing.Point(78, 499);
this.cboLevel.Name = "cboLevel";
this.cboLevel.Size = new System.Drawing.Size(294, 21);
this.cboLevel.TabIndex = 3;
// label1
this.label1.AutoSize = true;
this.label1.Location = new System.Drawing.Point(12, 502);
this.label1.Name = "label1";
this.label1.Size = new System.Drawing.Size(60, 13);
this.label1.TabIndex = 4;
this.label1.Text = "Pick Level:";
// label2
this.label2.AutoSize = true;
this.label2.Location = new System.Drawing.Point(12, 9);
this.label2.Name = "label2";
this.label2.Size = new System.Drawing.Size(112, 13);
this.label2.TabIndex = 4;
this.label2.Text = "Select Placed Rooms:";
// TestForm
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
this.ClientSize = new System.Drawing.Size(384, 561);
this.Controls.Add(this.label2);
this.Controls.Add(this.label1);
this.Controls.Add(this.cboLevel);
this.Controls.Add(this.listView1);
this.Controls.Add(this.btmOK);
this.Controls.Add(this.btnClose);
this.Name = "TestForm";
this.Text = "TestForm";
this.Load += new System.EventHandler(this.TestForm_Load);
this.ResumeLayout(false);
this.PerformLayout();
#endregion
private System.Windows.Forms.Button btnClose;
private System.Windows.Forms.Button btmOK;
private System.Windows.Forms.ListView listView1;
private System.Windows.Forms.ColumnHeader columnHeader3;
private System.Windows.Forms.ComboBox cboLevel;
private System.Windows.Forms.Label label1;
private System.Windows.Forms.Label label2;
Sean Page, AIA, NCARB, LEED APSenior Partner, Computational Designer, Architect
