Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to change text color ?
9 REPLIES 9
Message 1 of 10
3427 Views, 9 Replies
Hi everyone,
I am using the ColorDialog control from VisualStudio 2008 in order to
select a color and then I retrieve the RGB components in three variables:
ColorComponentRed
ColorComponentGreen
ColorComponentBlue
What I want is to assign this color to some text (it is text because it's
filtered as this) but the following code is not working:
[code]
Dim colorparam As Parameter
colorparam =
elem.ObjectType.Parameter(parameterId:=Parameters.BuiltInParameter.TEXT_COLOR)
Dim app As New Autodesk.Revit.Creation.Application()
Dim color As Autodesk.Revit.Color = app.NewColor()
color.Red = ColorComponentRed
color.Green = ColorComponentGreen
color.Blue = ColorComponentBlue
colorparam.Set(color)
[/code]
Can anybody tell me what I am doing wrong and how to do it, please ?
TIA
Humans are born with a wide horizon.
As time goes by, the horizon narrows and
narrows, until it becomes a point of view.
9 REPLIES 9
Message 2 of 10
I have the same problem. Did you find a solution?
Message 3 of 10
Do you want to change the color of an annotation in Revit? If so, have you tried opening a transaction to do that? You can only change anything in the model if it is inside a transaction.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Revit-API/files/GUID-...
Message 4 of 10
Revitalizer
private int GetRevitTextColorFromSystemColor(System.Drawing.Color color)
    return (int)color.R * (int)Math.Pow(2, 0) + (int)color.G * (int)Math.Pow(2, 8) + (int)color.B * (int)Math.Pow(2, 16);
...I know that 2^0 is just 1, so you could better use:
    return (int)color.R + (int)color.G * (int)Math.Pow(2, 8) + (int)color.B * (int)Math.Pow(2, 16);
Then, for example:
int color= GetRevitTextColorFromSystemColor(yourSystemColor);
textNoteType.get_Parameter(BuiltInParameter.LINE_COLOR).Set(color);
Also note that starting with Revit 2017, there is a ColorSelectionDialog available.
You can use its SelectedColor property to get a Revit color instead of a system color.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 5 of 10
jeremytammik
in reply to: Revitalizer
Dear Rudi,
Would this be equivalent (and faster) using the bitwise shift operator?
    /// <summary>
    /// Revit text colour parameter value stored as an integer
    /// in text note type BuiltInParameter.LINE_COLOR.
    /// </summary>
      System.Drawing.Color color )
      //return (int) color.R
      //  + (int) color.G * (int) Math.Pow( 2, 8 )
      //  + (int) color.B * (int) Math.Pow( 2, 16 );
        + (int) color.G << 8
        + (int) color.B << 16;
Thank you!
Cheers,
Jeremy
P.S. Probably not... cf. https://stackoverflow.com/questions/1933597/when-to-use-shift-operators-in-c
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 6 of 10
Revitalizer
in reply to: jeremytammik
Hi Jeremy,
I didn't use the bitwise operators so far,
but if providing the same result, it is the more elegant way.
One could replace the System.Drawing.Color by Autodesk.Revit.DB.Color,
the R, G, B properties by their Red, Green, Blue equivalent.
Rudi
Rudolf Honke
Software Developer
Mensch und Maschine
Message 7 of 10
jeremytammik
Dear Rudi,
I tried it out, but it seems to have no effect:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
      using( Transaction t = new Transaction( doc ) )
        t.Start( "Change Text Colour" );
        int color = Util.ToColorParameterValue(
          255, 0, 0 );
        Element textNoteType = doc.GetElement(
          txNote.GetTypeId() );
          BuiltInParameter.LINE_COLOR )
            .Set( color );
        t.Commit();
Any idea why?
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 10
FAIR59
the return value for the GetRevitTextColorFromSystemColor() method needs to be:
          return (int)( color.R + (color.G << 8)  + (color.B << 16));
Message 9 of 10
RPTHOMAS108
Quite convenient as extension methods:
 <Extension()> _
    Public Function AsRGB(ByVal Parameter As Parameter) As Byte()
        Dim I As Integer = Parameter.AsInteger
        Dim Red As Byte = I Mod 256
        I = I \ 256
        Dim Green As Byte = I Mod 256
        I = I \ 256
        Dim Blue As Byte = I Mod 256
        Return New Byte(2) {Red, Green, Blue}
    End Function
    <Extension()> _
    Public Function AsParameterValue(ByVal Color As Color) As Integer
        Return Color.Red + (256 * Color.Green) + (65536 * Color.Blue)
    End Function
    <Extension()> _
    Public Function AsParameterValue(ByVal Color As Windows.Media.Color) As Integer
        Return Color.R + (256 * Color.G) + (65536 * Color.B)
    End Function
    <Extension()> _
    Public Function AsParameterValue(ByVal Color As System.Drawing.Color) As Integer
    End Function
Message 10 of 10
jeremytammik
Thank you for the suggestions.
The problem was the .NET shift operator precedence.
Plus '+' tkaes higher precedence than left shift '<<', so I had to add parentheses like this:
    /// <summary>
    /// </summary>
    public static int ToColorParameterValue(
      int red,
      int green,
      int blue )
      return red + (green << 8) + (blue << 16);
Final result tested and working in The Building Coder samples:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/U...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Autodesk Customer Advisory Groups
Rail Community
