HI,NewTeeFitting() will create a fittings in default family,how can i create a fittings in custom family?
Solved by jeremytammik. Go to Solution.
There are probably several different ways to achieve this.
There are probably more ways besides.
Please explore your options in the user interface before attempting to program a solution.
You should always research the optimal workflow and best practices to address your task at hand manually through the user interface first.
To do so, please discuss and analyse it with an experienced application engineer, product usage expert, or product support.
Once you have got that part sorted out, it is time to step up into the programming environment.
hi,i am writing a program so i have to solve this problem by RevitApi,Can you elaborate how to Modify the MEP routing preferences by RevitApi?Thanks for your help
Please always search first before asking!
