how to capture the name of the file revit
Hi everyone
I am developing an addin revit, I need to capture the file name in a string variable when opened, someone has any idea how to do it?
arnostlobel
I assume you want to get to the name of a document an end user opens in Revit (via the UI File Open Dialog, or by drag and dropping) or another API application opens it using the Application.OpenDocumentFile method. If my assumption is correct, then the Application.DocumentOpened event is the solution you are looking for. The document that has just been opened will be available via the arguments of the event handler, and there you use either PathName or Title property depending on what you need.
Arnošt Löbel
Tanks Arnošt
Exist example to use Application.DocumentOpened event? help me please!
Regards
arnostlobel
There is a good chance such a sample exists. Start searching in the Samples folder provided with the SDK. There are definitelly samples of using various events, and it is very likely the DocumentOpened is among them. If not there, search the web with a simple "Application.DocumentOpened" query string - it should bring some samples, for this particular event is very often used by Revit programmers.
Arnošt Löbel
Hi everyone.
this is the answer to my request:
Dim uiapp As UIApplication = commandData.Application
uiapp.OpenAndActivateDocument("C:\example.rvt")
Dim FileOpened as String = commandData.Application.ActiveUIDocument.Document.PathName()
Regards!!!
