How to align a point to a reference Plane
Hi everybody,
By programming, i have created a sweep in the revit family template for ossature. I'm not able to align the start and end points of the curve used for sweeping with the corresponding reference plane.
Look at the GIF file to see exactly my problem.
Thanks for your answer.
Look the second GIF. The first is not good.
FAIR59
You have to find the sketch Line of the path first. This example works with ModelLines:
				ModelLine sweepPath = null;
				List<ElementId> deleted = null;
				using (Transaction t = new Transaction(doc,"deleteTemp"))
					t.Start();
					deleted = doc.Delete(sweep.Id).ToList();
					t.RollBack();
				List<ModelLine> pathCurveLoop = new List<ModelLine>();
				bool firstModellineSection = false;
				foreach( ElementId id in deleted)
					ModelLine ml = doc.GetElement(id) as ModelLine;
					if ( ml==null && firstModellineSection) break;
					if (ml == null ) continue;
					pathCurveLoop.Add(ml);
					firstModellineSection = true;
				sweepPath = pathCurveLoop.FirstOrDefault();
then you can lock the alignment to the referencePlane:
					bool alignFirstPoint ;
					Reference endPointRef = alignFirstPoint? sweepPath.GeometryCurve.GetEndPointReference(0): sweepPath.GeometryCurve.GetEndPointReference(1);
					doc.FamilyCreate.NewAlignment(doc.ActiveView, refPlane.GetReference(),endPointRef);
the method doc.FamilyCreate.NewAlignment won't work if the endpoint of the referenceLine doesn't lie on the referencePlane.
