How to add an existing filter to a view
I am trying to add filter to views. After I create the filter and add it to one view, I don't know how to add it
to the other views.
I tried to isolate the Creation in  a try Catch but I still need "parameterFilterElement" to use.
How can I add the same filter to other views?
  private void CreateViewFilter(  View view,string property, string filterName, string value, Color colo)
            var col = new FilteredElementCollector(doc);
            var elems = col.OfClass(typeof(FillPatternElement));
            string dx = "";
            ElementId xx = null;
            foreach(Element i in elems)
                dx += i.Name+"      "+i.Id+"\n";
                if (i.Name == "Solid fill")
                    xx = i.Id;
          // TaskDialog.Show("pattern", dx);
            List<ElementId> categories = new List<ElementId>();
            categories.Add(new ElementId(BuiltInCategory.OST_Walls));
            Transaction colorIt = new Transaction(doc, "the elements");
            ParameterFilterElement parameterFilterElement=null;
            colorIt.Start();
            try
                parameterFilterElement = ParameterFilterElement.Create(doc, filterName, categories);
            catch(Exception ex)
                TaskDialog.Show("Info", "Filter is already created ");
            FilteredElementCollector parameterCollector = new FilteredElementCollector(doc);
            Parameter parameter = parameterCollector.OfClass(typeof(Wall)).FirstElement().LookupParameter(property);
            List<FilterRule> filterRules = new List<FilterRule>();
            filterRules.Add(ParameterFilterRuleFactory.CreateEqualsRule(parameter.Id, value, true));
            parameterFilterElement.SetRules(filterRules);
             OverrideGraphicSettings filterSettings = new OverrideGraphicSettings();
            filterSettings.SetCutFillColor(colo);
            filterSettings.SetCutFillPatternId(xx);
            view.SetFilterOverrides(parameterFilterElement.Id, filterSettings);
            colorIt.Commit();
keith_white
Hi oakam.
First, you need to instantiate a parameter filter element object to use later in your code
ParameterFilterElement pfe = null;
Next, you need to collect all filters in the model.
FilteredElementCollector coll = new FilteredElementCollector(doc).OfClass(typeof(ParameterFilterElement));
Next check for the parameter filter using its name.
IEnumerable<Element> paramFilters = from element in coll where element.Name.Equals(name) select element;
Next Iterate over the IEnumerable collection (there should only be one, but just in case)
foreach (Element element in paramFilters)
    if (element.Name.Equals(name))
        pfe = element as ParameterFilterElement;
Next check the pfe for null and create if not found in the model
if (pfe == null)
   ...you can use your code here to create the parameter filter element
  pfe = CreateParameterFilterElement(doc, parameterFilterName, categoryIds)
Next build out the Override Graphics Settings and add the parameter filter element to the view that was collected or created in the steps above
    ...you can use your code here to build out the override graphics settings
    OverrideGraphicSettings ogs = new OverrideGraphicSettings();
    ...you can use your code here to add the parameter filter element to the view using the pfe.id value
    uiDoc.ActiveView.SetFilterOverrides(pfe.Id, ogs);
You will need to wrap the above within a transaction and sub-transactions to commit the changes, but that should be easy enough.
I hope this helps.
Keith
Keith White
Principal Solution Architect, Autodesk Consulting
DollyPortis-WPM
Thank you so much for your solution. It helped me to finally get my plugin to work right.
