I have a issue while developing a project that i need to select all the leaders in "Revit" file and i want change alignment of all the leaders with dragging elbow and end point.
Solved by moturi.magati.george. Go to Solution.
Hi @praveen.cMXB2H,
I didn't quite get your question but if you want to manipulate the aignment of the TextNote Leader, here is the best place to start
https://thebuildingcoder.typepad.com/blog/2014/02/textnote-leader-alignment.html
I will explain my question with using below diagram. In the below "ABC" ,"AA" are text notes and added leader manually and remaining all are independent tags created with Tag by Category option. Here my question is i want select all the leaders in the given below i want to change alignment of the leaders with using elbow and end point. Here can i drag elbow and change leader alignment.
