How to acces all view sheet sets in document
c_hanschen
c_hanschen
I'm able to make New sheet set of access the active sheet set, but how can i access all view sheet sets in the active document?
Chris Hanschen
The Netherlands
c_hanschen
My post was a little bit to short! sorry.
It says the topic has been ascalated, why?
more details:
I'm able to access the PrintManager.ViewSheetSetting.CurrentViewSheetSet to get al list of al views and/or sheets to print.
I can also make my own list and save it, no problem there.
But how can i acces the other ViewSheetLists that are saved in the document?
i have tried: (vb.net)
Dim MyElementCollectorSheetsSets As FilteredElementCollector = New FilteredElementCollector(MyDoc)
MyElementCollectorSheetsSets.OfClass(GetType(IViewSheetSet))
message:
Autodesk.Revit.Exceptions.ArgumentException: Input type(Autodesk.Revit.DB.IViewSheetSet) is not a recognized Revit API type
Parameter name: type
any help will be appreciated!
Chris
The Netherlands
JimJia
Dear Chris Hanschen,
Please try code below, hope it's helpful:
public Result Execute(ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
// find all viewsheet set within document
Document doc = commandData.Application.ActiveUIDocument.Document;
FilteredElementCollector coll = new FilteredElementCollector(doc);
var all = coll.OfClass(typeof(ViewSheetSet)).ToElements();
Console.WriteLine("Viewsheet set count: " + all.Count);
foreach (ViewSheetSet vss in all)
Console.WriteLine("Name: " + vss.Name);
return Result.Succeeded;
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: [email protected]
