Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Select point from form
I'm updating an old add-on. I am trying to place a TextNote at a specific location. It works fine if I supply it an XYZ point. But I cannot get it to work by using Document.Selection.Pickpoint. The code below is called from a separate form. I can't even catch an exception, revit becomes unresponsive. How would I pick a point then pass it to the TextNote.Create method? Thanks.
        public void CreateText()
            RevitView curView = m_revit.ActiveUIDocument.Document.ActiveView;
            //XYZ origin = new XYZ(10, 10, 0);
            XYZ orgin = m_document.Selection.PickPoint("Pick Note Location");
            ElementId defaultTypeId = m_revit.ActiveUIDocument.Document.GetDefaultElementTypeId(ElementTypeGroup.TextNoteType);
            TextNote note = TextNote.Create(m_revit.ActiveUIDocument.Document, curView.Id, orgin, "TEXT NOTE", defaultTypeId);
Mustafa.Salaheldin
You have to put your code in the Revit API context. This means either hide your form to set control back to Revit before calling the PickPoint function or put the PickPoint function in External Event and fire the event from the Form.
Don't forget to inclose the TextNote.Create () in a Transaction.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Thank you for your reply. I'm in the process of splitting up the Command and Form into separate distinct files. I hadn't been that careful about that when I was learning, and that was on R13 when you could still get away with that. Anyway, yes, I believe I have done that. But I agree that it has something to do with how I'm handling the form. The first chuck of code below is from the command and handles the transaction and initially displaying the form. I've removed a small piece regarding the expiration date.
The second is from the form. There is actually quite a bit of code in the form, very little of it relating to Revit and it works fine when I have a set XYZ point. I have experimented with passing a reference to the Document to the form and getting the point from there. And the way it's currently set up, trying to get the point within the command.
Command:
    public class CreateTextNoteCommand : Autodesk.Revit.UI.IExternalCommand
        public Autodesk.Revit.UI.UIApplication m_revit = null;
        UIDocument m_document;
        public Result Execute(Autodesk.Revit.UI.ExternalCommandData revit, ref string message, ElementSet elements)
            m_revit = revit.Application;
            m_document = m_revit.ActiveUIDocument;
            Transaction trans = new Transaction(m_revit.ActiveUIDocument.Document, "Create Text Note");
            trans.Start();
            try
                bool checkDate = CheckDate();
                if (!checkDate)
                    trans.RollBack();
                    return Result.Failed;
                using (CreateTextNoteForm displayForm = new CreateTextNoteForm(this))
                    if (displayForm.ShowDialog() != DialogResult.OK)
                        trans.RollBack();
                        return Result.Cancelled;
                trans.Commit();
                return Result.Succeeded;
            catch (Exception ex)
                message = ex.Message;
                trans.RollBack();
        public void CreateNote(String note)
            try
                XYZ selectedPoint = m_document.Selection.PickPoint("Pick Note Location");
                TextNote _TextNote = TextNote.Create(
                    curView.Id,
                    selectedPoint,
                    note,
                    defaultTypeId
                MessageBox.Show(ex.ToString());
                throw;
Form:
        private void button3_Click(object sender, EventArgs e)
            ProcessDialog();
            this.Hide();
            //GetPoint();
            m_commandData.CreateNote(textNote);
            this.DialogResult = DialogResult.OK;
            this.Close();
jeremytammik
Dear Bthatcher,
Thank you for your query, and thanks to Mustafa for the very valid point.
Look at the Revit SDK ModelessForm_ExternalEvent to see how to handle this.
Lots more background information is provided in The Building Coder topic group on Idling and External Events for Modeless Access and Driving Revit from Outside:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.28
A similar issue was recently discussed in another thread:
http://forums.autodesk.com/t5/revit-api/managing-transaction-in-a-function-initiated-from-a-modeless...
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Mustafa.Salaheldin
Please try this
In the Form:
    public partial class CreateTextNoteForm : Form
        ExternalEvent m_ex = null;
        public CreateTextNoteForm(UIApplication app, ExternalEvent exEvent)
            InitializeComponent();
            m_ex = exEvent;
        private void button1_Click(object sender, EventArgs e)
            m_ex.Raise();
The External command shall be:
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                //TODO: add your code below.
                TextInsertHandler handler = new TextInsertHandler();
                ExternalEvent exEvent = ExternalEvent.Create(handler);
                CreateTextNoteForm displayForm = new CreateTextNoteForm(cmdData.Application, exEvent);
                displayForm.Show();
                msg = ex.ToString();
        public class TextInsertHandler : IExternalEventHandler
            public String GetName()
                return "R2014 External Event Sample";
            public void Execute(UIApplication uiapp)
                try
                    using (Transaction trans = new Transaction(uiapp.ActiveUIDocument.Document, "Create Text Note"))
                        trans.Start();
                        CreateNote("test");
                        trans.Commit();
                catch (Exception ex) { }
                return;
        }  // class
        public static void CreateNote(String note)
            try
                Autodesk.Revit.DB.View curView = _cachedCmdData.Application.ActiveUIDocument.ActiveView;
                XYZ selectedPoint = _cachedCmdData.Application.ActiveUIDocument.Selection.PickPoint("Pick Note Location");
                ElementId defaultTypeId = _cachedCmdData.Application.ActiveUIDocument.Document.GetDefaultElementTypeId(ElementTypeGroup.TextNoteType);
                    _cachedCmdData.Application.ActiveUIDocument.Document,
                    curView.Id,
                    selectedPoint,
                    note,
                    defaultTypeId
                throw;
If this is the solution you seek please mark this reply as an answer
¯\_(ツ)_/¯
Mustafa Salaheldin
