How order selected faces
AndrewButenko
AndrewButenko
Hello! I try select few faces of wall programaticaly. But Revit order faces by ElementId. I need order faces by selecting. Anybody help please!
Dim sel = revit.Application.ActiveUIDocument.Selection
       Dim refers As List(Of Reference) = Nothing
            refers = sel.PickObjects(ObjectType.Face)
jeremytammik
If you need to keep track of the order in which the user selected the individual objects, you cannot use PickObjects.
You can switch to PickObject instead, and select the objects one by one in a loop.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
AndrewButenko
Dear Jeremy!
Possible you have any example?
