How get coordinates of Section Box?
AndrewButenko
AndrewButenko
Hello!
I draw boundary lines of section box with next code:
 Dim startView As View3D = doc.ActiveView
            Dim ln As Line
            Dim p1 As XYZ = New XYZ(startView.GetSectionBox.Min.X, startView.GetSectionBox.Min.Y, 0)
            Dim p2 As XYZ = New XYZ(startView.GetSectionBox.Min.X, startView.GetSectionBox.Max.Y, 0)
            ln = Line.CreateBound(p1, p2)
            drawCurveDoc(doc, ln)
            p1 = p2
            p2 = New XYZ(startView.GetSectionBox.Max.X, startView.GetSectionBox.Max.Y, 0)
            p1 = p2
            p2 = New XYZ(startView.GetSectionBox.Max.X, startView.GetSectionBox.Min.Y, 0)
            p1 = p2
            p2 = New XYZ(startView.GetSectionBox.Min.X, startView.GetSectionBox.Min.Y, 0)
But my model lines  far away of selection box:
aignatovich
Hi!
Your bounding box has transform, that differs from Transform.Identity. So, you should apply transform to min & max points and use transform basic vectors to determine box lines direction, or calculate corner points and apply transform to them
AndrewButenko
Do you have example?
aignatovich
Look at this:
            var uiapp = commandData.Application;
            var uidoc = uiapp.ActiveUIDocument;
            var doc = uidoc.Document;
            var view = doc.ActiveView as View3D;
            if (view == null || !view.IsSectionBoxActive)
                message = "This works only in 3D views with activated section box";
                return Result.Failed;
            var box = view.GetSectionBox();
            var points = new[]
                    box.Min,
                    new XYZ(box.Max.X, box.Min.Y, box.Min.Z),
                    new XYZ(box.Max.X, box.Max.Y, box.Min.Z),
                    new XYZ(box.Min.X, box.Max.Y, box.Min.Z)
                .Select(box.Transform.OfPoint)
                .Select(x => new XYZ(x.X, x.Y, 0))
                .ToList();
            var lines = new[]
                    Line.CreateBound(points[0], points[1]),
                    Line.CreateBound(points[1], points[2]),
                    Line.CreateBound(points[2], points[3]),
                    Line.CreateBound(points[3], points[0])
            using (var transaction = new Transaction(doc, "draw box"))
                transaction.Start();
                var sketchPlane = SketchPlane.Create(doc, Plane.CreateByNormalAndOrigin(XYZ.BasisZ, XYZ.Zero));
                foreach (var line in lines)
                    doc.Create.NewModelCurve(line, sketchPlane);
                transaction.Commit();
AndrewButenko
Thank you. It's work!
User_2011
How do you upload it in Revit and how do you execute it, what command / shortcut?
I'm sure is similar to CAD with APPLOAD lisp, but I am new in Revit and frustrated that i am forced to work in Revit.
