How execute a VB.NET 2012 class from a Button on my form - Revit addin
Hello everyone
I am developing a Revit addin using Vb.net 2012 I made a class to create a project (rvt) based on a template (rte). Now I need to execute or call my class from a button on my form. How I execute the class? someone has an example ?. this is my code.
In The Form1
Private Sub Btt_Crear_Click(sender As Object, e As EventArgs) Handles Btt_Crear.Click
  Dim plt As New PLT_ARQ
  plt.Execute()
End Sub
in the Class PLT_ARQ
Imports System
Imports System.IO
Imports System.Diagnostics
Imports System.Collections.Generic
Imports Autodesk.Revit.ApplicationServices
Imports Autodesk.Revit.Attributes
Imports Autodesk.Revit.DB
Imports Autodesk.Revit.UI
Imports Autodesk.Revit.UI.Selection
<Transaction(TransactionMode.Manual)>
Public Class PLT_ARQ
    Implements IExternalCommand
    Public Function Execute(
      ByVal commandData As ExternalCommandData,
      ByRef message As String,
      ByVal elements As ElementSet) _
    As Result Implements IExternalCommand.Execute
        Dim uiapp As UIApplication = commandData.Application
        Dim uidoc As UIDocument = uiapp.ActiveUIDocument
        Dim app As Application = uiapp.Application
         If form.SaveFileDialog1.ShowDialog() = Windows.Forms.DialogResult.OK Then
                Dim CurrentPath As String = "C:\"
                Dim TemplateFile As String = "model.rte"
                Dim templateFullPath As String = System.IO.Path.Combine(CurrentPath, TemplateFile)
                Dim newDoc As Document = app.NewProjectDocument(templateFullPath)
                Dim newFileName As String = System.IO.Path.Combine(form.SaveFileDialog1.InitialDirectory, form.SaveFileDialog1.FileName)
                newDoc.SaveAs(newFileName)
                newDoc.Close()
                uiapp.OpenAndActivateDocument(newFileName)
        End If
        Return Result.Succeeded
    End Function
End Class
Hi marcosmateo!
From your original post it's unclear if you created a class that extends IExternalApplication. This is a class that is automatically/manually loaded when Revit starts up. Also in this class you define "RibbonTab"s, "RibbonPanel"s, "RibbonButton"s and assign IExternalCommand classes (like the one you created) to those buttons. A simple example can be shown in the sticky thread in Revit API subforum (MyFirstRevitPlugin).
