How do i uninstall Dynamo from Revit 2020?
gvlohuizen
gvlohuizen
How can i uninstall dynamo from revit 2020? It really slows down starting Revit.
I develop my own add-ins so i don't need Dynamo.
jeremytammik
That is not really a Revit API question, is it?
Hence, this is not really the right place to try to discuss it.
You might have better luck in the Dynamo forum:
https://forum.dynamobim.com
Otherwise, you should try one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
gvlohuizen
Hi Jeremy,
Thanks for your reply!
I'm new to this forum, sorry 😉
I will try my luck at the Dynamo-forum.
Gerrit
