How do I make add-in using out from opened document?
XARMA
XARMA
I have saw some add-in that can be used without opening rvt file.
I face some error message, If I execute my dll file eventhough any simple codes it is.
Syetem.NullReferenceException: Object reference not set to an instance of an object at A.Command.Execute(ExternalCommandData commandData, String& message, ElementSet elements) at ...
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @XARMA ,
If you want logic that runs when Revit starts (before any file is opened), implement IExternalApplication and use OnStartup:
public class MyApp : IExternalApplication
    public Result OnStartup(UIControlledApplication application)
        // Add UI or run logic here
        return Result.Succeeded;
    public Result OnShutdown(UIControlledApplication application)
Also, please take a look at the links
https://help.autodesk.com/view/RVT/2024/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_...
If this doesn't help, Could you please explain your issue in more detail?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
