Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
how do i get rotation of wall using revit api?
5 REPLIES 5
arvind.maurya37
5027 Views, 5 Replies
How do i get rotation of wall using revit api?
 if a Element is family instance then
 (FamilyInstance.Location as LocationPoint).Rotation;
i can easily get a the rotation easily.
if i try for wall
Curve curve = ((Wall).Location as LocationCurve).Curve;
or any thing like that.
Tags (2)
5 REPLIES 5
so-chong
in reply to: arvind.maurya37
The Revit API Developers Guide has some examples (Code Region 10-6)
Maybe this is helpful to you.
http://help.autodesk.com/view/RVT/2019/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Basic_Interact...
Hope this helps.
arvind.maurya37
in reply to: so-chong
Hii,
thanks for the reply.
(Code Region 10-6)
bool LocationRotate(Autodesk.Revit.ApplicationServices.Application application, Autodesk.Revit.DB.Element element)
    bool rotated = false;
    // Rotate the element via its location curve.
    LocationCurve curve = element.Location as LocationCurve;
    if (null != curve)
        Curve line = curve.Curve;
        XYZ aa = line.GetEndPoint(0);
        XYZ cc = new XYZ(aa.X, aa.Y, aa.Z + 10);
        Line axis = Line.CreateBound(aa, cc);
        rotated = curve.Rotate(axis, Math.PI / 2.0);
    return rotated;
above code will rotate the wall with some given angle and return true or false.
i want something like
1) drawn a wall and rotated the wall with 90 Degree.
wall given for rotation 90 degreewall given for rotation 90 degree
2) i need to get the rotation value like ( in this case it is 90 degree).wall after rotating 90 degreewall after rotating 90 degree
needed the rotated value. via api .
I just answered your identical question on StackOverflow:
https://stackoverflow.com/questions/52302648/how-do-i-get-rotation-of-wall-using-revit-api
If your wall curve is a straight line, you can just grab the angle from the line: let V be the vector from the wall curve start to end point, and determine its angle to the X axis:
  angle = V.AngleTo( XYZ.BasisX );
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
in reply to: jeremytammik
Hi @jeremytammik ,
If I want to get the rotation for a structural column element, do I need to use the "LocationPoint.Rotation" approach?
Regards
jeremytammik
I believe there are two different type of columns: vertical and tilted.
https://thebuildingcoder.typepad.com/blog/2009/06/creating-a-slanted-column.html
I believe the vertical ones use the location point approach, and the tilted to location line.
https://thebuildingcoder.typepad.com/blog/2011/03/slanted-column-cross-section-rotation.html
Please let us know how you end up solving this.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
