How do I continue after postcommand?
SimonaQQ
Message 1 of 9
SimonaQQ
PostCommand is always executed at the end, similar to "promptforfamilyinstanceplacement". How can I continue other operations after postcommand?
For "promptforfamilyinstanceplacement", I usually catch "operationcanceledexception" to continue execution, but this is not valid for postcommand, such as
uidoc.Application.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.MirrorPickAxis));
So, what should I do?
Thank you very much!!
Replies (8)
Message 2 of 9
jeremy_tammik
You can subscribe to the Idling event:
https://www.revitapidocs.com/2022/e233027b-ba8c-0bd1-37b7-93a066efa5a3.htm
Your handler will be called after Revit has completed all active commands, e.g., your PostCommand activity.
You can specify that Idling be called once only, and you can unsubscribe from it right away after the first call, directly in the event handler.
Lots of samples by The Building Coder:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.28
Message 3 of 9
ricaun
You could use a custom class like RevitCommandEndedMonitor that uses the idling exactly like @jeremy_tammik suggests.
Where I found the reference: https://forums.autodesk.com/t5/revit-api-forum/a-question-about-suppressing-warning-messages-in-revi...
Here is my example: https://gist.github.com/ricaun/cc4f0a39b36006883f091bc7f0fc3d35
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Events;
using System;
namespace RevitAddin
    [Transaction(TransactionMode.Manual)]
    public class CommandMoveEnd : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elementSet)
            UIApplication uiapp = commandData.Application;
            RevitCommandEndedMonitor revitCommandEndedMonitor = new RevitCommandEndedMonitor(uiapp);
            revitCommandEndedMonitor.CommandEnded += OnCommandEnded;
            uiapp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.Move));
            return Result.Succeeded;
        private void OnCommandEnded(object sender, EventArgs e)
            TaskDialog.Show("Revit", "Move End");
    public class RevitCommandEndedMonitor
        private readonly UIApplication _revitUiApplication;
        private bool _initializingCommandMonitor;
        public event EventHandler CommandEnded;
        public RevitCommandEndedMonitor(UIApplication revituiApplication)
            _revitUiApplication = revituiApplication;
            _initializingCommandMonitor = true;
            _revitUiApplication.Idling += OnRevitUiApplicationIdling;
        private void OnRevitUiApplicationIdling(object sender, IdlingEventArgs idlingEventArgs)
            if (_initializingCommandMonitor)
                _initializingCommandMonitor = false;
                return;
            _revitUiApplication.Idling -= OnRevitUiApplicationIdling;
            OnCommandEnded();
        protected virtual void OnCommandEnded()
            CommandEnded?.Invoke(this, EventArgs.Empty);
See yaa
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 4 of 9
SimonaQQ
Perfect!
Thank you!!!
Your help is greatly appreciated!
Message 5 of 9
SimonaQQ
Message 6 of 9
adcdao
Thank you ricaun, it's working very well.
Also I used that with PostRequestForElementTypePlacement for placement of family instance. I combined that with this code from Jeremy Tammik (https://thebuildingcoder.typepad.com/blog/2015/02/sending-escape-to-terminate-a-family-instance-plac...) to add only one instance at a time.
Thank you again!
André
Message 7 of 9
Chuong.Ho
It can't resolve the problem when we use Revit Link Command
RevitCommandId revitCommandId = RevitCommandId.LookupPostableCommandId(PostableCommand.LinkRevit);
uiApp.PostCommand(revitCommandId);
Dialog will be show and also execute CommandEnded at the same time.
Chuong Ho
Message 8 of 9
ricaun
I tested it in Revit 2021 and works normally. The link dialog opens and after closing the OnCommandEnded fires.
Technically the RevitCommandEndedMonitor code is triggering in the second Idling event, kinda odd that PostCommand is executing before the Idling event in your case.
I was experimenting with using DocumentChanged to get the element that changes/created in the PostCommand, maybe this could be a better approach.
Message 9 of 9
miguelBW5DE
Is there a way to know when the user cancel the postable command?
I just came up with this workaround:
			List<Element> regions = new FilteredElementCollector(doc).OfClass(typeof(FilledRegion)).WhereElementIsNotElementType().ToList();
			//the user cancelled the command
			if(regionCount == regions.Count){
				return;
I'm comparing the number of filled regions existing in the project before and after executing the postable command, but couldn't find a decent way to do this using the IdlingEventArgs.IsCancelled() / Cancellable nor /cancel commands.
Best regards,
Miguel G.
