How can replace text in Textnote by keeping same formatting
kite15
kite15
I am trying to replace the text with another text by keeping same formatting (Revit 2020).
Actually, there have a same discussion:
https://forums.autodesk.com/t5/revit-api-forum/replace-text-in-text-note-and-keep-formatting/m-p/347...
Have tried as per above discussion, However, after replace the text its became all as under line text formatting...
 Code:
TextNote textNote = revitDocument.GetElement(elementId) as TextNote;
                            FormattedText formattedText = textNote.GetFormattedText();
                            TextRange range = formattedText.AsTextRange();
                            string plainText = textNote.Text;
                            if (!string.IsNullOrEmpty(updatedText))
                                plainText = plainText.Replace(searchedText, updatedText);
                                formattedText.SetPlainText(range, plainText);
                            textNote.SetFormattedText(formattedText);
Please, help
hmunsell
i don't see anything in that code that would make it underline. it may be coming from the text type.
if its a text note in Revit, depending on where the underlining is set, you have 2 options. Option 1 is global, option 2 is by instance.
  1. select the Text Type, Edit Type, and uncheck the Underline option.
  2. double click on the text, select all and unselect the Underline option in the ribbon.
Howard Munsell
kite15
1. It's happening due to first word is formatted with underline.
2. I am looking for automation not considering the manual approach
please, suggest regarding the text formatting automation procedure for TextNote element in Revit API2020, in that case.
Thank you
hmunsell
so you know what is causing the problem then. It is the first word, which is probably edited by double clicking on the text and only selecting that word to underline (vs being a type setting). The code is just selecting the style of the first word and applying it to the whole text string. not sure your gonna be able to easily get around that in the code.
  • is the REF (highlighted in green) the only thing changing?
  • is it the same in all instances or does it change?
Could you use the native Find and Replace tool in Revit?
Howard Munsell
FAIR59
a FormattedText can have multiple ranges, first you'd have to find the range  of the searchText, and then you can update only that range.
TextRange range = formattedText.Find(searchedText,0,false,false);
string plainText = textNote.Text.Substring(range.Start,range.Length);
kite15
Hi FAIR59,
Thank you very much its working fine..😊
Not sure if this issue has been resolved, but here is a lengthy method for maintaining formatting when text is replaced:
void ReplaceTextInTextNote(TextNote txnote,
int index, //index of first character in text to be replaced
int range, //number of characters to be replaced
string addText) //text to replace the removed characters
                FormattedText ftx = txnote.GetFormattedText();
                string newText = txnote.Text;
                //Collect Current UnderlineStatuses, BoldStatuses, italicstatuses, superscriptStatuses, per char in txno.Text
                List<bool> underlineStatuses = new List<bool>();
                List<bool> boldStatuses = new List<bool>();
                List<bool> italicStatuses = new List<bool>();
                List<bool> superscriptStatuses = new List<bool>();
                List<bool> subscriptStatuses = new List<bool>();
                for (int i = 0; i < txno.Text.Length; i++)
                    if (ftx.GetUnderlineStatus(new TextRange(i, 1)).ToString() == "All") { underlineStatuses.Add(true); }
                    else { underlineStatuses.Add(false);  }
                    if (ftx.GetBoldStatus(new TextRange(i, 1)).ToString() == "All") { boldStatuses.Add(true); }
                    else { boldStatuses.Add(false); }
                    if (ftx.GetItalicStatus(new TextRange(i, 1)).ToString() == "All") { italicStatuses.Add(true); }
                    else { italicStatuses.Add(false); }
                    if (ftx.GetSuperscriptStatus(new TextRange(i, 1)).ToString() == "All") { superscriptStatuses.Add(true); }
                    else { superscriptStatuses.Add(false); }
                    if (ftx.GetSubscriptStatus(new TextRange(i, 1)).ToString() == "All") { subscriptStatuses.Add(true); }
                    else { subscriptStatuses.Add(false); }
                //Remove Replaced Text
                underlineStatuses.RemoveRange(index, range);
                boldStatuses.RemoveRange(index, range);
                italicStatuses.RemoveRange(index, range);
                superscriptStatuses.RemoveRange(index, range);
                subscriptStatuses.RemoveRange(index, range);
                newText = newText.Remove(index, range);
                //Add new Text
                newText = newText.Insert(index, addText);
                //Shall the inserted Text be underlined, bold
                bool underlineAddText = ftx.GetUnderlineStatus(new TextRange(index, 1)).ToString() == "All";
                bool boldAddText = ftx.GetBoldStatus(new TextRange(index, 1)).ToString() == "All";
                bool italicAddText = ftx.GetItalicStatus(new TextRange(index, 1)).ToString() == "All";
                bool superscriptAddText = ftx.GetSuperscriptStatus(new TextRange(index, 1)).ToString() == "All";
                bool subscriptAddText = ftx.GetSubscriptStatus(new TextRange(index, 1)).ToString() == "All";
                //Add the same formatting to a list to be added to underline,bold, italic, subscript, superscript statuses
                underlineStatuses.InsertRange(index, (Enumerable.Repeat(underlineAddText, addText.Length)));
                boldStatuses.InsertRange(index, (Enumerable.Repeat(boldAddText, addText.Length)));
                italicStatuses.InsertRange(index, (Enumerable.Repeat(italicAddText, addText.Length)));
                superscriptStatuses.InsertRange(index, (Enumerable.Repeat(superscriptAddText, addText.Length)));
                subscriptStatuses.InsertRange(index, (Enumerable.Repeat(subscriptAddText, addText.Length)));
                //Set New Text
                txnote.Text = newText;
                FormattedText ftx2 = txnote.GetFormattedText();
                //Set Underline Status
                for (int i = 0; i < underlineStatuses.Count; i++)
                    if (underlineStatuses[i] == true) { ftx2.SetUnderlineStatus(new TextRange(i, 1), true); }
                    else { { ftx2.SetUnderlineStatus(new TextRange(i, 1), false); } }
                    if (boldStatuses[i] == true) { ftx2.SetBoldStatus(new TextRange(i, 1), true); }
                    else { { ftx2.SetBoldStatus(new TextRange(i, 1), false); } }
                    if (italicStatuses[i] == true) { ftx2.SetItalicStatus(new TextRange(i, 1), true); }
                    else { { ftx2.SetItalicStatus(new TextRange(i, 1), false); } }
                    if (superscriptStatuses[i] == true) { ftx2.SetSuperscriptStatus(new TextRange(i, 1), true); }
                    else { { ftx2.SetSuperscriptStatus(new TextRange(i, 1), false); } }
                    if (subscriptStatuses[i] == true) { ftx2.SetSubscriptStatus(new TextRange(i, 1), true); }
                    else { { ftx2.SetSubscriptStatus(new TextRange(i, 1), false); } }
                txnote.SetFormattedText(ftx2);
