How can I get the center point of the part of wall which inside the room?
ddk0705
ddk0705
I've used this logic to get all walls of a room:
List<Wall> walls = new List<Wall>();
IList<IList<BoundarySegment>> boundaries = room.GetBoundarySegments(new SpatialElementBoundaryOptions());
foreach (IList<BoundarySegment> b in boundaries)
    foreach (BoundarySegment s in b)
        Element el = document.GetElement(s.ElementId);
        if (el is Wall)
            Wall wall = el as Wall;
            walls.Add(wall);
However, some walls are longer than edge of the room as this photo
Basically, 1 part is a wall of the Resi Trash - 158 room (blue border).
So, I want to get the 1a part (red border) which has located inside the room and getting the center point of the 1a part.
FAIR59
You can use the boundary Curve to find the midpoint on the RoomWall  ( and the direction into the Room ).
List<Tuple<Wall,XYZ,XYZ>> walls = new List<Tuple<Wall,XYZ,XYZ>>(); // Item1 = wall, Item2 = midpoint, Item3 = direction to Room
		Element el = doc.GetElement(s.ElementId);
		if (el is Wall)
       			Curve cv = s.GetCurve();
       			XYZ mid = cv.Evaluate(0.5,true); // midpoint on BoundaryCurve
       			// XYZ midpointOmWall = (wall.Location as LocationCurve).Curve.Project(mid);
       			XYZ directionToRoom  = cv.ComputeDerivatives(0.5,true).BasisX.CrossProduct(XYZ.BasisZ).Negate().Normalize();
       			walls.Add(new Tuple<Wall,XYZ,XYZ>(wall,mid,directionToRoom));
using (Transaction t = new Transaction(doc,"show_midpoints"))
	t.Start();
	foreach(var tuple in  walls)
		XYZ midpoint = tuple.Item2;
		try{
doc.Create.NewDetailCurve(doc.ActiveView,Line.CreateBound(midpoint,midpoint+tuple.Item3.Multiply(5)));
		catch{}
	t.Commit();
ddk0705
Thanks @FAIR59  I think it's a good solution.
