How can I edit List<Curve> of Rebar same as tool "edit sketch rebar"
I 'm coding some addin to trim rebar , extent rebar and split rebar.
Problem: I can't find a function in SDK Revit 2017 and SDK revit 2018, to edit/ set List<Curve> of Rebar same as tool "Edit sketch" (path: Modify|Structural Rebar/Mode/Edit sketch)
now, My solution is not good, first, i get Ilist <Curve> of Rebar by 2 function ,
in revit 2017:
rebar.ComputeDrivingCurves();
rebar.GetCenterlineCurves();
in revit 2018:
rebar.GetShapeDrivenAccessor().ComputeDrivingCurves();
I create new List<Curve>, then I create new rebar,finally I delete old rebar = > Problem: Dimension and tags of old rebar will be deleted
jamess166
I also want to know how to do that, you found the solution.
Same problem here, have any of you found more elegant solution than deleting and recreating rebar?
@Anonymous
@jamess166
If you are creating a free form rebar, you can simply call SetCurves() method.
