Debug messages with SharpDevelop
VaclavC
VaclavC
  I'am trying to write simple macros in Revit. Frist I tried some in RevitPythonShell (https://github.com/architecture-building-systems/revitpythonshell). They are working. Now I'am trying to work with something prebuilt in Revit, so I'am trying Macro manager with SharpDevelop (preinstalled). Trying with Python and C#. It seems to work, but I'am missing debug messages. Tried Debug.WriteLine(...) in C#, but the output is nowhere show. How can I produce any debug messages with Revit and SharpDevelop?
jeremytammik
You could always print to a file and view that in an editor side by side.
I implemented a simple error log that you could base you debug messaging system on in
https://github.com/jeremytammik/rvtmetaprop
Look at these lines, and all the lines putting together the list of leog message strings:
https://github.com/jeremytammik/rvtmetaprop/blob/master/rvtmetaprop/Command.cs#L426-L437
If you close the file after every line and your editor support live updates, you should see the messages appear as they are created.
There are certainly other, better, simpler and more proper (properer?) ways of handling this as well.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
VaclavC
Good idea, thank you.
Revitalizer
there is also an Application.WriteJournalComment method, so you could use Revit's built-in logging file(s).
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
