How can I delete backup file?
XARMA
XARMA
The folder is maded by central file like name "centralfilename"_bakcup in same folder with central file.
I have to delete this folder but I couldn't delete .bak files with message that ".bak files are working". but there are no user on central file that time. I can't understand this situation and please give me advice. thank you
moturi.magati.george
Hi @XARMA,
You might not receive the help you need on this forum as this forum is focused on Revit API programming.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us.
However, you can try to verify that no other Revit process or remote user is using the file before removing it.
  Moturi George,     Developer Advocacy and Support,  ADN Open
