How can I create a ViewSchedule with only the elements of a ViewPort ?
Bruno_Neves_Pires_Silva
Hello, Folks.
   I'm trying to create a ScheduleFilter, but until now I couldn't do it.
    I thought in creating first a ScheduleField with the type ScheduleFieldType.ViewBased, but what BuiltInParameter I would use ?
   Thank you in advance.
aignatovich
Hi!
There is no schedule for viewports, but you can schedule model views.
Create schedule using ViewSchedule.CreateViewList method, add field with BuiltInParameter.VIEWPORT_SHEET_NAME and add filter for this parameter (it is enough to create filter rule for this value, that should begins with empty string)
Thank you, Aignatovich.
     But what I really need is a schedule for a specific viewport, there are many viewports in the sheet...
jeremytammik
Dear Bruno,
Thank you for your query, and thanks to Alexander for his helpful suggestion.
Bruno, can you achieve what you need manually through the user interface?
How?
Have you analysed the resulting structure using RevitLookup?
If it is possible, then that should give you all the information required to recreate it programmatically.
Here is some advice on researching how to solve a Revit programming task:
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
RPTHOMAS108
From memory Schedules on a sheet are represented by ScheduleSheetInstance not ViewPort and have a property .ScheduleId.
