How can I calculate Text Note height without making a commit for performance
WorldDue
WorldDue
In case of inserting many Text notes, I want to commit once without making sub Transactions or such which is costly to performance.
So how can I pre-calculate the text height in C#
Can I use the Graphics.MeasureString() function? If so how can I set the size and width of the TextNoteType in C# Graphics module, and also what about the units used in both the API and the Graphics c# class..
Thanks.
jeremy_tammik
Well, apparently querying the bounding box requires a regeneration; that is a lot less heavy than a sub-transaction or transaction:
https://thebuildingcoder.typepad.com/blog/2016/05/idea-station-and-textnote-bounding-box.html#3
Here is a sample showing how to use MeasureText:
https://thebuildingcoder.typepad.com/blog/2014/10/new-text-note-and-text-width-calculation.html
I hope that is useful.
jeremy_tammik
I just noticed that you already studied this related solution:
https://forums.autodesk.com/t5/revit-api-forum/textnote-height/m-p/8045275
Adding the pointer for others searching the same...
