How assign "floortype" to NewFloor ?
bdsas081914
bdsas081914
I'm new to Revit's API.
I will not be assigned floor type.
Because I do not know "Revit 2014 API HELP" Explanation.
Are there any examples available online?
please help me.
Thank you!
Document.NewFloor Method (CurveArray, FloorType, Level, Boolean, XYZ)
public Floor NewFloor(
CurveArray profile,
FloorType floorType,
Level level,
bool structural,
XYZ normal
floorType
Type: Autodesk.Revit.DB.FloorType
A floor type to be used by the new floor instead of the default type.
jeremytammik
Dear bdsas081914,
You can retrieve all floor types from the project document using a filtered element collector.
Then it is up to you which one of them you want to use.
Here is an example of doing exactly that:
http://thebuildingcoder.typepad.com/blog/2011/08/floor-creation.html
The Building Coder provides a few other examples of creating floors as well, if you take a look.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
bdsas081914
Thank you Jeremy explanation.
