Hotfix 22.0.2.392 - SVG graphics don't render in plug-in
jonathan.pickeringEQZBX
The Chorus NBS plug-in works fine on older versions of Revit (22.0.2.392 and before) but on the latest hotfix version (22.1.10.541) the SVG images fail to render in Chorus. This is a web page in a browser plug-in. The web pages all work fine when loaded in the Chrome browser outside of Revit.
Is there something in this hot-fix that would stop SVG images rendering in a browser plugin?
Has there been a change of embedded browser used by Revit for such plug-ins?
jeremy_tammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
As far as I can tell from your question, you are not doing anything programmatically yourself, just using the standard Revit user interface and existing third-party add-ins.
So, you cannot expect an answer to such a question relating to system requirements, installation, product setup, optimisation, usage or other end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to address this topic than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
