Hoe to get the value inside the parameters that are not BuiltIn parameters
mahshid.motie
737 次查看
2 条回复
1 条消息(共 3 条)
mahshid.motie
I have created the parameter "Instance_Name" for all of the elements in my project and its has value in some of the elements and its empty in the rest. I want to check the value of the parameter but I dont know how to access it. Using revitlookup I found out that it exists in parameters. I have tried different methods like:
IList<Parameter> p = EF.GetParameters("Instance_Name");
string pp = p[0].ToString();
Parameter ppp = EF.LookupParameter(pp);
string pppp = ppp.AsString();
TaskDialog.Show("instance name", pppp);
or
Parameter p = EF.LookupParameter("Instance_Name");
string pp = p.AsString();
TaskDialog.Show("instance name", pp);
Can you help me?
0 个赞
已接受的解答 (1)
738 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
jeremytammik
已接受的解答
This question has been answered many times over elsewhere.
Your second code snippet is fine, with some caveats: avoid using the display name if possible, and it only works of you can guarantee that there is only one parameter with this display name. GetParameters returns all parameters with a given display name. get_Parameter also takes a GUID, if your parameter is a shared parameter.
https://thebuildingcoder.typepad.com/blog/2015/02/family-instance-area-and-auto-loading-a-project-fi...
https://thebuildingcoder.typepad.com/blog/2015/06/cnc-direct-export-wall-parts-to-dxf-and-sat.html#2...
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
3 条消息(共 3 条)
mahshid.motie
Thanks for the answer Jeremy 🙂
0 个赞
