Hide elements in linked file
Message 1 of 25
Manually this is possible in revit. I have main doc and a linked doc. Now I select one element from main doc and one element from linked doc; I do a right click and Hide In View - Elements. Both the selected element gets hidden.
Trying to do the same via code:
FilteredElementCollector links = new FilteredElementCollector(Command.doc).OfCategory(BuiltInCategory.OST_RvtLinks);
            foreach (Document d in Command.app.Documents)
                coll = new FilteredElementCollector(d);
                coll.WherePasses(new LogicalOrFilter(new ElementIsElementTypeFilter(false), new ElementIsElementTypeFilter(true)));
                elemSet = new ElementSet();
                foreach (Element el in coll)
                    try
                        if (el.Id == new ElementId(elementid1) || el.Id == new ElementId(elementid2)
                            IList<ElementId> ilds = new List<ElementId>();
                            ilds.Add(el.Id);
                            ICollection<ElementId> elemIdsColl = (ICollection<ElementId>)ilds.Cast<ElementId>().ToList();
                            Command.doc.ActiveView.HideElements(ilds);
                    catch (Exception sd)
                        string fg = sd.ToString();
The code hides only the element of the main doc but does not hide the element of the linked doc.
Thanks & Regards
Sanjay Pandey
Replies (24)
Message 21 of 25
lvirone
@JeremyvU2GS6 happy to help. So you achieved to change the activeView then calling multiple postCommand one after another ? Or did you found another way ? Thanks
Yes, PostCommand is not the most optimized way to do stuff, so it can be slow. When you touch to UI it can slow the process too.
Message 22 of 25
JeremyvU2GS6
Yup watch it open each view and operate restarting each time. I can post code later if you need
Message 23 of 25
lvirone
@JeremyvU2GS6 Thank you for confirming the process I described works, happy to have helped !
Message 24 of 25
DollyPortis-WPM
Here is the python code to select elements by selection and hide them:
doc = revit.doc
uidoc = revit.uidoc
class LinkInstanceSelectionFilter(ISelectionFilter😞
    def AllowElement(self, element😞
        return isinstance(element, DB.RevitLinkInstance)
    def AllowReference(self, reference, position😞
        return True
sel = revit.uidoc.Selection
selection_filter = LinkInstanceSelectionFilter()
selected_reference = sel.PickObject(ObjectType.Element, selection_filter, "Select a linked model")
# Get the RevitLinkInstance element
link_instance = revit.doc.GetElement(selected_reference.ElementId)
# Get the linked document from the selected RevitLinkInstance
linked_doc = link_instance.GetLinkDocument()
if linked_doc is None:
    raise Exception("Failed to retrieve the linked document.")
# Step 2: User selects elements in the linked model
with forms.WarningBar(title="Pick elements in linked model"😞
    linked_sel_filter = LinkedElementSelectionFilter()
    selected_refs = uidoc.Selection.PickObjects(ObjectType.LinkedElement, linked_sel_filter)
    linked_element_ids = [ref.LinkedElementId for ref in selected_refs]
# Step 3: Create link references for selected elements
refs = [DB.Reference(linked_doc.GetElement(eid)).CreateLinkReference(link_instance) for eid in linked_element_ids]
# Step 4: Select these references in the UI
uidoc.Selection.SetReferences(refs)
# Step 5: Hide the selected elements in the active view
uidoc.Application.PostCommand(
    RevitCommandId.LookupPostableCommandId(PostableCommand.HideElements)
Message 25 of 25
sragan
Here is my code for a Revit 2025 Macro using the new VS Code Editor, and letting the user pick the elements to hide:
public void HideLinkedElements()
            UIDocument uidoc = this.ActiveUIDocument;
            Document doc = this.ActiveUIDocument.Document;
            IList<Reference> elist = uidoc.Selection.PickObjects(ObjectType.LinkedElement, "Pick Elements");
            if (elist.Count > 0) uidoc.Selection.SetReferences(elist);
            //TaskDialog.Show("Number of Elements", elist.Count.ToString());
            uidoc.Application.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.HideElements));
            //uidoc.Application.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.HideCategory));
            //uidoc.Application.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.HalftoneOrUnderlay));
            //TaskDialog.Show("Hidden", "Hidden");
You have the option of using HideCategory or HideElements.   The HalftoneOrUnderlay setting opens the halftone dialog box, but it only seems to work for the entire link.
It is a little slow - a couple of times I didn't think it worked because I didn't wait a second or two.   And sometimes it doesn't seem to work when only selecting one element.   It seems like either just selecting elements or Tab-Selecting does the same thing, except sometimes Tab-select seems to work better with single element selections.
Also, it's not that hard to unhide elements - just select "Revel Hidden Elements", and pick and right click to "unhide".
