Message 1 of 25
03:12 AM
- Mute
- Permalink
- Report
Manually this is possible in revit. I have main doc and a linked doc. Now I select one element from main doc and one element from linked doc; I do a right click and Hide In View - Elements. Both the selected element gets hidden.
Trying to do the same via code:
FilteredElementCollector links = new FilteredElementCollector(Command.doc).OfCategory(BuiltInCategory.OST_RvtLinks);
foreach (Document d in Command.app.Documents)
coll = new FilteredElementCollector(d);
coll.WherePasses(new LogicalOrFilter(new ElementIsElementTypeFilter(false), new ElementIsElementTypeFilter(true)));
elemSet = new ElementSet();
foreach (Element el in coll)
try
if (el.Id == new ElementId(elementid1) || el.Id == new ElementId(elementid2)
IList<ElementId> ilds = new List<ElementId>();
ilds.Add(el.Id);
ICollection<ElementId> elemIdsColl = (ICollection<ElementId>)ilds.Cast<ElementId>().ToList();
Command.doc.ActiveView.HideElements(ilds);
catch (Exception sd)
string fg = sd.ToString();
The code hides only the element of the main doc but does not hide the element of the linked doc.
Thanks & Regards
Sanjay Pandey
