Help Please! Revit 2018
I am trying to download the student version of Revit 2018, but can't activate the program.  The serial number and product keep never matches.  Where can I get new codes from?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
This forum is only for API (Application Programming Interface) questions for Revit add-on development.
Regarding Installation and licensing, You can to ask your questions in below-mentioned forum.
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
What do you mean by new code?
Are you trying to create Revit Plugin code?
If yes then you can start with RevitMyFirstPlugin
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
