For lecturing purposes, we conduct virtualization platforms with Revit v2021 to run there.
While Revit operates on virtual Win 10 Desktop Images (VDI) with hardware acceleration, no GPU is found on a terminal server (RDS). This seems strange because hardware and software are equal both on RDS and TS.
Could you please provide advice in terms of using Revit v2021 on a terminal server while enabling GPU acceleration?
Thanks in Advance!
Thanks in Advance!
Solved by naveen.kumar.t. Go to Solution.
Hi @bastian.plass ,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
The people there are much better equipped to answer your question than us.
I hope this clarifies.
Hi @bastian.plass ,
