Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Handle DocumentCorruption error when linking IFC
0 REPLIES 0
Message 1 of 1
antonio90rodriguez
199 Views, 0 Replies
antonio90rodriguez
Hi there!
I am trying to link an IFC model into a Revit file, from an add-in, by using the following code extracted from a dynamo node in the  Genius Loci package.
IFCImportOptions ifcImportOptions = new IFCImportOptions();
ifcImportOptions.Intent = IFCImportIntent.Reference;
ifcDoc = app.OpenIFCDocument(ifcFiles.First(), ifcImportOptions);
SaveAsOptions saveAsOptions = new SaveAsOptions();
saveAsOptions.OverwriteExistingFile = true;
RevitLinkOptions revitLinkOptions = new RevitLinkOptions(true);
string rvtFilePath = ifcFiles.First() + ".rvt";
ifcDoc.SaveAs(rvtFilePath, saveAsOptions);
ifcDoc.Close(false);
LinkLoadResult ifcLoadResult = RevitLinkType.CreateFromIFC(doc, ifcFiles.First(), rvtFilePath, false, revitLinkOptions);
The code works like a charm, but Revit throws the following error message.
From dynamo I would manually click on `Continue Without Save`  and the process of linking the IFC will continue and complete successfully.
The problem comes when I use that code inside an `IExternalEventHandler` for my Revit add-in `IExternalCommand`, as the error can't be handled until the entire add-in code has finish running. Therefore when the code reaches line 9 `SaveAs()`, it fails as there is an active Error that can't be omitted.
I have tried to handle the error from `App.cs` with the following code but without luck, and I can see that the default resolution is `Save File And Continue` which doesn't work in this case, I need to be able to programatically resolve the error with the `Continue Without Save`.
private void CheckWarnings(object sender, FailuresProcessingEventArgs e)
            FailuresAccessor accessor = e.GetFailuresAccessor();
            FailureHandlingOptions op = accessor.GetFailureHandlingOptions();
            op.SetForcedModalHandling(false);
            accessor.SetFailureHandlingOptions(op);
            IList<FailureMessageAccessor> failList = accessor.GetFailureMessages(); // Inside event handler, get all warnings
            foreach (FailureMessageAccessor failure in failList)
                // check FailureDefinitionIds against ones that you want to dismiss,
                FailureDefinitionId failID = failure.GetFailureDefinitionId();
                // prevent Revit from showing Unenclosed room warnings
                if (failure.GetSeverity() == FailureSeverity.DocumentCorruption)
                    e.SetProcessingResult(FailureProcessingResult.ProceedWithCommit);
            e.SetProcessingResult(FailureProcessingResult.Continue);
Any ideas on how can I do that?
Hi there!
Labels (6)
0 REPLIES 0
