Half of Icons missing when trying to open a file on revit 2017
I recently started use Revit and every time I try to open a file, half of the icons are missing and the Look in bar is also cut in half.  It can get annoying and its hard for me to open files.  I have a Lenovo Yoga 720 if that matters.  I have also attached a picture of the issue.
jeremytammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
