group placement
group placement
group placement
I am experiencing a strange behavior. I place a group via code and the group gets rotated on its own. Also when manually pacing the group always a box comes shows up with the cursor prompting the user to place the group but when I prompt the user to place the group via "
Selection.PickPoint("Please pick a point.");
no box shows up with the cursor
UIDocument uidoc = uiapp.ActiveUIDocument;
                            FilteredElementCollector collector = new FilteredElementCollector(Command.doc).OfClass((typeof(GroupType)));
                            var groupTypes = from element in collector
                                             where element.Name == "test"
                                             select element;
                            Element groupType = groupTypes.First();
                            GroupType ty = (GroupType)groupType;
try
                            XYZ targetPoint = Command.uidoc.Selection.PickPoint("Please pick a point.");
                            using (Transaction trans = new Transaction(uidoc.Document))
                                    trans.Start("sun");
                                   Group dt= uidoc.Document.Create.PlaceGroup(targetPoint, ty);
                                    trans.Commit();
                                catch (Exception ex)
                                    string ee = ex.ToString();
stever66
No box shows up because you are picking the point before you start the group placement.   Why not try combining 2 lines into a single line of code:
Instead of:
and;
try something like this:
Group dt= uidoc.Document.Create.PlaceGroup(Command.uidoc.Selection.PickPoint("Please pick a point."), ty);
Thanks for the reply. But the result was same.
Thanks & Regards
Sanjay Pandey
was able to tackle the problem. ungrouped the group and created a new group.
but still the following problem remails unresolved
