Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Grid extension Length
1 REPLY 1
433 Views, 1 Reply
Hi
Does anyone knows where to set up the default grid extension length?
On section or plan view, when grids (but also levels) are visible, they have a constant extension length from the crop region.
looking for weeks know to change this length but didn't found anything yet...
Hi
1 REPLY 1
bhprest
bhprest
I cannot tell if this is an API question. This forum is for programming in Revit using the API.
If this is about operating the application as a user, you may have better luck posting this question in the Revit Architecture Forum. https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
If this is about the API, please take a look at this method on the Grid Class:
https://www.revitapidocs.com/2020/eaff0038-34f2-03cf-185b-2872cffb84af.htm
*** Please note, I haven't ever used this method, so I can't speak to whether it works or not. But it seems to me that it would be the solution to your issue.
Good luck.
Good luck.
