Getting the shape of a FamilyInstance object
I want to get the shape of a FamilyInstance object (for different instances).
Preferably, I would like to get the Solid object that describes it and then traverse its faces.
I'm not sure what is the easy way to do that (before looking into corner-cases).
I thought of checking its `HasModifiedGeometry()`, if it returns False, to do that:
foreach (GeometryObject geomObj in familyInstance.get_Geometry(opt))
    if (geomObj is Solid geomSolid)
        // GOOD
    else
        // Should I do anything here?
And if it returns False - to do the same for the FamilySymbol (familyInstance.Symbol):
foreach (GeometryObject geomObj in familyInstance.Symbol.get_Geometry(opt))
        // GOOD
    else
But in this case, I should probably add the `familyInstance.Location`?
Is it correct?
Is it even the idea to follow with, or should I do something completely different
buihaviet
You can use this method in SDK examples to extract the solids of Element:
public static IList<Solid> GetTargetSolids(Element element)
            List<Solid> solids = new List<Solid>();
            Options options = new Options();
            options.DetailLevel = ViewDetailLevel.Fine;
            GeometryElement geomElem = element.get_Geometry(options);
            foreach (GeometryObject geomObj in geomElem)
                if (geomObj is Solid)
                    Solid solid = (Solid)geomObj;
                    if (solid.Faces.Size > 0 && solid.Volume > 0.0)
                        solids.Add(solid);
                    // Single-level recursive check of instances. If viable solids are more than
                    // one level deep, this example ignores them.
                else if (geomObj is GeometryInstance)
                    GeometryInstance geomInst = (GeometryInstance)geomObj;
                    GeometryElement instGeomElem = geomInst.GetInstanceGeometry();
                    foreach (GeometryObject instGeomObj in instGeomElem)
                        if (instGeomObj is Solid)
                            Solid solid = (Solid)instGeomObj;
                                solids.Add(solid);
            return solids;
Cheer,
Viet.
