Getting the path for the program data folder
stever66
Advisor Advisor
stever66
I need to load an image file from the program data folder, like this:
Uri uriImage = new Uri(@"C:\ProgramData\Autodesk\ApplicationPlugins\\MyIcon32x32.png");
But on different computers, the folder may be on the "D:\" drive, or any other drive letter.
How do I rewrite this line so it works on any computer?
Since my .dll file should be in the same folder, I tried using @".\MyIcon32x32.png".   I also tried just "MyIcon32x32.png", but neither worked.
Dear stever,
As i know best way to keep icons file into embeded resource. To do this you can follow below instruction.
To Show as icon: You Can use following Code:
Step 2:
 static BitmapSource GetEmbeddedImage(string name)
            try
                Assembly a = Assembly.GetExecutingAssembly();
                Stream s = a.GetManifestResourceStream(name);
                return BitmapFrame.Create(s);
            catch
                return null;
PushButtonData pbdBop = new PushButtonData("pbdBop", @"B.O.P", assemFullName, "AddIns2014.BOP"); PushButton pbBop = panel.AddItem(pbdBop) as PushButton; pbBop.ToolTip = @" Click to get BOP"; pbBop.LargeImage = GetEmbeddedImage("AddIns2014.Images.BOPNew.ico"); panel.AddSeparator();
Dale.Bartlett
If you want the location of the executing dll, I have been using this for some time (not original):
// using System.Reflection;
        // return dll locations
        public static string GetDLLFolder()
            System.Reflection.Assembly Asmbly = null;
            string lstrDllLocation = string.Empty;
            // get current dll name
            string lstrDllName = System.Reflection.Assembly.GetExecutingAssembly().GetName().Name;
            foreach (System.Reflection.Assembly Asmbly_loopVariable in System.AppDomain.CurrentDomain.GetAssemblies())
                Asmbly = Asmbly_loopVariable;
                lstrDllLocation = Asmbly.Location.ToString();
                string lstrDllNameTest = Path.GetFileNameWithoutExtension(lstrDllLocation);
                if (lstrDllName.ToUpper() == lstrDllNameTest.ToUpper())
                    break;
            return lstrDllLocation;
______________
Yes, I'm Satoshi.
Very Simple
String ProgramDataFolder= Environment.GetFolderPath(Environment.SpecialFolder.CommonApplicationData);
Enjoy
Thanks & Regards
Sanjay Pandey
stever66
Thanks for 3 excellent suggestions.
I'll have to look into the embeded resources a little more.   Does that embed the image file in the .dll file, or is it in another file?   The .dll file is the only file (besides the addin file and the image file) that gets transfered to other computers.  I'm not moving the entire VS solution folder to other computers.
Dale:  I'll have to try that code section sometime.   It looks like it has the ability to return multiple paths (maybe if there are different addins in different directories?)
Sanjay's solution worked for me.  I was actually using something similar to find the AppData path.  I tried to modify it by changing "AppData" to "ProgramData", but that wasn't a valid keyword.  I didn't realize "CommonApplicationData" was the keyword I was looking for.
Dale.Bartlett
Just keep in mind that Environment.SpecialFold​er.CommonApplicationData is not necessarily the executing dll's folder.
______________
Yes, I'm Satoshi.
