Getting the location of hooks in a rebar shape family
FrodeTo
6,867件の閲覧回数
22件の返信
メッセージ1/23
FrodeTo
When editing a Rebar Shape family I would like to find out what lines in the family the hooks are attached to. In other words I would like the id of the line the start hook is attached to and the coordinate of this hook.
I have written code to edit the family and I do find the rebar lines and the dimensions, but I cannot find any way to locate the placement of the hooks. Any help is appreciated.
regards
Frode
0 件のいいね
解決済み
6,868件の閲覧回数
22件の返信
返信 (22)
メッセージ2/23
jeremytammik
Dear Frode,
Thank you for your query.
I do not know off-hand, so I am asking the development team for help.
Hang on...
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
メッセージ3/23
jeremytammik
Dear Frode,
Thank you for your patience with this.
I heard back now from the development team. They say:
After further investigations I found that this is indeed a tricky subject.
There is no clear/easy way to obtain what the user asked for. (I could not find any API methods for retrieving the position of the hooks in relation to the RebarShape Family lines).
It would be helpful to know more high-level details about what the user wants to obtain.
Could you provide me a scenario?
I am thinking of this one but I need to be sure this is what the user wants.
The user wants to edit the shape family so that all rebars in the model will get a hook at a certain/expected end.
These details would help us decide if we need to implement a new method for API, or if we can suggest some other solutions.
Could you please provide the desired background information so we can raise a wish list item for this?
Best of all would be in the form of a reproducible case including a minimal testing BIM and some sample code illustrating what does and does not work:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
メッセージ4/23
FrodeTo
Hi Jeremy.
Thank you for investigating.
What we are trying to do here is to create images of the rebars that will be used in a report. We are able to produce the image shown below, but we would like to be able to put hooks on the image as well. The actual geometry of the hook is not that important. What we need is the hook angle, what end is "Hook at Start" connected to and what is the orientation of the hook.
The code is too long to show here, but what we do is to call EditFamily on the shape. Then we create the rebars shape from the model lines in the family. The dimension lines and text are created from the dimension elements. If there are other ways to create this image we will be very happy. Please note that we need both the hooks and the dimesions in our figur.
regards
Frode
メッセージ5/23
jeremytammik
Dear Frode,
Thank you for your update, which I passed on to the development team.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
0 件のいいね
メッセージ6/23
tiberiu_pinzariu
解決済み
Hello Frode,
You can get the shape centerlines (without hooks) in order (from start to end) with the following method  :
   IList<Curve> curvesForBrowser = rebarShape.GetCurvesForBrowser();
Note: You should be able to retrieve the RebarShape element from the family document.
Hook information can be retrieved through methods:
                    int hookangle0 = rebarShape.GetDefaultHookAngle(0);
                    RebarHookOrientation orient0 = rebarShape.GetDefaultHookOrientation(0);
                    int hookangle1 = rebarShape.GetDefaultHookAngle(1);
                    RebarHookOrientation orient1 = rebarShape.GetDefaultHookOrientation(1);
Hook position should be as follows:
   Start hook origin point should be : curvesForBrowser[0].GetEndPoint(0);
   End hook origin point should be : curvesForBrowser[curveSize -1].GetEndPoint(1);
And the connection between the curvesForBrowser and the dimensions in the family can be retrieved like this:
1. Map the dimensions to their label parameter ids.
            IDictionary<ElementId, ElementId> labelParamIdToDimId = new Dictionary<ElementId, ElementId>();
            foreach (Dimension dim in familyDimensions)
                try
                    FamilyParameter famParam = dim.FamilyLabel;
                    if (null == famParam)
                        continue;
                    labelParamIdToDimId[famParam.Id] = dim.Id;
                catch (Autodesk.Revit.Exceptions.InvalidOperationException)
                    continue;
2.Get the constraint information from the shape definition.
            // Get the shape definition : constraints should be available for every definition.
            // Get all the shape segments (indexes of segments) and their corresponding constraint parameter ids
            // The RebarShapeSegment should be in the same order as the curvesForBrowser.
            // The constraint param ids  should correspond to the dimension label param ids.
            RebarShapeDefinitionBySegments defBySeg = rebarShape.GetRebarShapeDefinition() as RebarShapeDefinitionBySegments;
            IDictionary<int, string> segmentPosToLabel = new Dictionary<int, string>();
            for (int ii = 0; ii < defBySeg.NumberOfSegments; ii++)
                RebarShapeSegment seg = defBySeg.GetSegment(ii);
                IList<RebarShapeConstraint> constraints = seg.GetConstraints();
                foreach (RebarShapeConstraint constraint in constraints)
                    ElementId paramID = constraint.GetParamId();
                    if ((paramID == ElementId.InvalidElementId) || !labelParamIdToDimId.ContainsKey(paramID))
                        continue;
                    string labelName = "";
                    foreach (Parameter param in rebarShape.Parameters)
                        if (param.Id == paramID)
                            labelName = param.Definition.Name;
                            break;
                    segmentPosToLabel.Add(ii, labelName);
Finally you should be able to retrieve/create all the curves and their corresponding dimensions:
            IList<Curve> curvesForPicture = new List<Curve>();
                Curve curve = curvesForBrowser[ii];
                string label = "";
                if (!segmentPosToLabel.TryGetValue(ii, out label))
                    continue;
Please let me know if this works for you.
Tiberiu
メッセージ7/23
jeremytammik
Dear Tiberiu,
Thank you very much for researching and sharing this important solution!
Dear Frode,
Does this solve your issue?
If so, could you please mark it as an accepted solution?
Thank you!
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
0 件のいいね
メッセージ8/23
jeremytammik
Dear Frode,
We are still eagerly awaiting your confirmation that this works for you.
In the meantime, I cleaned up and published this thread for legibility and posteriority:
http://thebuildingcoder.typepad.com/blog/2016/04/location-of-hooks-in-a-rebar-shape-family.html
Thanks you again, Tibi, for your research!
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
0 件のいいね
メッセージ9/23
FrodeTo
Sorry for the late replay. I've been away on vacation.
Thank you Tiberiu for the suggestions. However I did not manage to use this exactly as you describe. The information that the curves for browser is correctly ordered is very helpful. But unfortunatly the shape from curves for browser is not identical to the shape in the family. And I need the lines in the family to draw the dimension lines. What I have done instead is to use the information from the curves from browser to determine what segments in the family that the hooks are connected to. This seems to work. At the moment the code is not publishable as it's quite long and experimental.
Thank you for the help!
If it's possible to wish for a new function in the API I very much would like a funkction that gets the picture shown in the Revit Shape Browser with both the hooks and the dimension.
regards
Frode
0 件のいいね
メッセージ10/23
tiberiu_pinzariu
You are welcome.
I will pass the API request to my team and we will consider it in the near future.
We will let you know when we have updates on this matter.
Tibi
0 件のいいね
メッセージ11/23
適用対象外
 Hi this all looks good but can't get past the first hurdle:
1. foreach (Dimension dim in familyDimensions)
How do I obtain familyDimensions (and annotations) for the rebar?
0 件のいいね
メッセージ12/23
FrodeTo
You have to open the family for edit (document.EditFamily) and iterate the Dimension's in the family document.
0 件のいいね
メッセージ13/23
適用対象外
Hi FrodeTo
have you a sample for open the family for edit (document.EditFamily) and iterate the Dimension's in the family document?
thanks
Stefano
0 件のいいね
メッセージ14/23
適用対象外
Hi Stefano,
This is what I ended up with (data is an array of dimension name-value pairs, and SegInfo struct definition is at the end):
private List<List<SegInfo>> GetDimensionInfo(Dictionary<string, int> data, RebarShape rebarShape) { IEnumerable<Dimension> dims = null; var infoLists = new List<List<SegInfo>>(); var rebar = _Document.GetFamilySymbolrebarShape.Name); if (rebar != null) { var doc = _Document.EditFamily(rebar.Family); dims = doc.GetTypes<Dimension>().Where(x => HasLabel(x)); } // get the shape definition RebarShapeDefinitionBySegments shapeDef = rebarShape.GetRebarShapeDefinition() as RebarShapeDefinitionBySegments; // get the dimension name and value for each segment for (int i = 0; i < shapeDef.NumberOfSegments; i++) { RebarShapeSegment segment = shapeDef.GetSegment(i); var constraints = segment.GetConstraints(); var infoList = new List<SegInfo>(); foreach (var constraint in constraints) { ElementId id = constraint.GetParamId(); if ((id == ElementId.InvalidElementId)) continue; var p = rebarShape.get_Parameter(id); if (p == null) continue; // store segment information SegInfo sd; sd.name = p.Definition.Name; sd.value = data[sd.name]; sd.constraint = constraint; sd.dimension = dims?.Where(x => x.FamilyLabel.Id == id).FirstOrDefault(); infoList.Add(sd); } infoLists.Add(infoList); } return infoLists; } private struct SegInfo { public string name; public double value; public RebarShapeConstraint constraint; public Dimension dimension; }
0 件のいいね
メッセージ15/23
適用対象外
I will try it!!
0 件のいいね
メッセージ16/23
適用対象外
Hi Stefano,
My edit timed out but here is the code for GetTypes<T>():
public static IList<T> GetTypes<T>(this Document document) where T : Element
            return new FilteredElementCollector(document)
                .OfClass(typeof(T))
                .Cast<T>()
                .ToList();
Also  a typeo at the line GetFamilySymbolrebarShape.Name) is missing a bracket:  GetFamilySymbol(rebarShape.Name).
You may not need the Dimenison dictionary if you have the rebar instance available.
0 件のいいね
メッセージ17/23
適用対象外
I try to convert it to Vb.NET, but I receive  this error " line 1 col 9: invalid TypeDecl"
0 件のいいね
メッセージ18/23
適用対象外
Your on your own with VB!
0 件のいいね
メッセージ19/23
適用対象外
Hi FrodeTo,
How did you get the images for the rebars?
Senne
0 件のいいね
メッセージ20/23
1368026189
Hello  FrodeTo:
I got the same Requirement as you descibe,So can you share your solution to us dispite the long code?
Thanks a lot!!!
0 件のいいね
