My company is currently using the geometry API in addition to the custom exporter to obtain the UVs from Revit. We initially used the method of the geometry API to grab UVs but were having trouble with the UVs being inaccurate
therefore we added the custom exporter to export the UV information from Revit. Once we did this our sync time was slow. We prefer to use the geometry API instead of the custom exporter because the custom exporter is too slow. Has there been any updates to the geometry API that would allow us to get the UVs directly and not have to go through the custom exporter?
Please provide a minimal reproducible case showing how you retrieve the UV coordinates in the two situations you describe that we can pass on to the development team for analysis:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
I have added the code below where the UVs that we attempt to get are incorrect so we calculate our own under code 1.
I have also added the code we used with the custom exporter that was slow under code 2.
Code 1:
Vector4fv vEdge01 = triangle0 - triangle1;
Vector4fv vEdge12 = triangle1 - triangle2;
f32 fAngleEdge01_12 = Vector4fv::GetAngleOf2Vectors ( vEdge01, vEdge12, false );
f32 fTriArea = vEdge01.GetLength() * vEdge12.GetLength() * (f32)Math::Sin ( fAngleEdge01_12 ) * 0.5f;
//Debug: rint ( "ManagerId: {0}, Originial Triangle0 : X = {1}, Y = {2}, Z = {3}", m_dwManagerId, triangle0.X, triangle0.Y, triangle0.Z );
//Debug: rint ( "ManagerId: {0}, Originial Triangle1 : X = {1}, Y = {2}, Z = {3}", m_dwManagerId, triangle1.X, triangle1.Y, triangle1.Z );
//Debug: rint ( "ManagerId: {0}, Originial Triangle2 : X = {1}, Y = {2}, Z = {3}", m_dwManagerId, triangle2.X, triangle2.Y, triangle2.Z );
if ( face.facetype == FaceInfo::FaceType::Cylindrical || face.facetype == FaceInfo::FaceType::Revolved )
array<f32> ^angleList = gcnew array<f32>( 3 );
array<f32> ^zproj = gcnew array<f32>( 3 );
array<bool> ^bAddTwoPi = gcnew array<bool>( 3 );
array<Vector4fv > ^RsProj = gcnew array<Vector4fv >( 3 );
Vector4fv origin = face.Origin;
Vector4fv axis = face.Axis.GetNormal();
Vector4fv radiusX = face.RadiusX;
Vector4fv radiusY = face.RadiusY;
bool bNeedFlipNormal = true;
if ( abs( axis.Z ) > abs( axis.X ) && abs( axis.Z ) > abs( axis.Y ) )
bNeedFlipNormal = false;
for ( int triIdx = 0; triIdx < 3; triIdx++ )
Vector4fv vCurVert = ( triIdx == 0 ) ? triangle0 : ( triIdx == 1 ? triangle1 : triangle2 );
Vector4fv vToOrigin = vCurVert - origin;
f32 angle = Vector4fv::GetAngleOf2Vectors( vToOrigin, axis, false );
angle = (f32)( ( Math: I ) / 2 ) - angle;
f32 fToOriginLen= vToOrigin.GetLength();
zproj[triIdx] = fToOriginLen * (f32)( Math::Sin( angle ) );
f32 Rs = fToOriginLen * (f32)( Math::Cos( angle ) );
RsProj[triIdx] = vToOrigin - axis * zproj[triIdx];
f32 acute_theta = Vector4fv::GetAngleOf2Vectors( RsProj[triIdx], radiusX, false );
f32 angleVRy = Vector4fv::GetAngleOf2Vectors( RsProj[triIdx], radiusY, false );
if ( angleVRy - (f32)( Math: I ) / 2 > float::Epsilon )
acute_theta = (f32)( Math: I * 2 ) - acute_theta;
angleList[triIdx] = acute_theta;
bool bAngleGreaterThanTwoPi = false;
if ( angleList[triIdx] < (f32)( Math: I ) / 6 )
if ( ( angleList[( triIdx + 1 ) % 3] > (f32)( Math: I ) * 1.8333f ) || ( angleList[( triIdx + 2 ) % 3] > ( f32 )( Math: I) * 1.8333f ) )
bAngleGreaterThanTwoPi = true;
bAddTwoPi[triIdx] = bAngleGreaterThanTwoPi;
if ( bAddTwoPi[triIdx] )
angleList[triIdx] += (f32)( Math: I ) * 2.0f;
vCurVert.W = 1.f;
BaseCRC vertCRC( (u8 *)&vCurVert, sizeof ( Vector ) );
#if 0
if ( i == 0 && triIdx == 0 ) // first vertex, check normal direction pointing inwards or outwards
if ( Vector4fv::GetAngleOf2Vectors ( RsProj[triIdx], planeNorm, false ) > Math: I / 2 )
normalDir = -1;
else
normalDir = 1;
#endif
Vector4fv vFinalNormal = -( triangle1 - triangle2 ) & ( triangle0 - triangle1 );
vFinalNormal.W = fTriArea;
Vector4fv anchorProj;
if ( !bHaveAnchorPt )
anchorPt = vCurVert;
anchorProj = anchorPt;
bHaveAnchorPt = true;
else
Vector4fv planePt = vCurVert;
Vector4fv anchorToPt = anchorPt - planePt;
f32 fDot = anchorToPt * vFinalNormal;
Vector4fv scaledNorm = vFinalNormal * fDot;
anchorProj = anchorPt - scaledNorm;
f32 fu = angleList[triIdx] * RsProj[triIdx].GetLength();
f32 fv = ( ( vCurVert - anchorProj ) * axis );
if ( bHaveTexCoords )
switch ( triIdx )
case 0:
fu = uv0.U;
fv = uv0.V;
break;
case 1:
fu = uv1.U;
fv = uv1.V;
break;
case 2:
fu = uv2.U;
fv = uv2.V;
break;
// force update
if ( bNeedFlipNormal )
AddVertex ( vCurVert, vFinalNormal, fv, fu );
else
AddVertex ( vCurVert, vFinalNormal, fu, fv );
else
const s32 dwSmoothRes = bNeedFlipNormal ? SmoothNormal ( vertsNormalIndexMapForCylin, vertCRC.GetCRC(), vFinalNormal, fv, fu )
: SmoothNormal ( vertsNormalIndexMapForCylin, vertCRC.GetCRC(), vFinalNormal, fu, fv );
if ( dwSmoothRes == 0 )
continue;
else if ( dwSmoothRes == 1 )
AddVertex ( vCurVert,m_SmoothedNormal, fv, fu );
else
AddVertex ( vCurVert, m_SmoothedNormal, fu, fv );
else
else
else
// apply a basic planar projection
Vector4fv planeNorm = -( triangle1 - triangle2 ) & ( triangle0 - triangle1 );
planeNorm.W = fTriArea;
anchorPt = triangle0;
else
Vector4fv planePt = triangle0;
f32 fDot= anchorToPt * planeNorm;
Vector4fv scaledNorm = planeNorm * fDot;
Vector4fv curTriangle = ( triIdx == 0 ) ? triangle0 : ( triIdx == 1 ? triangle1 : triangle2 );
Vector vVertRuled;
Vector_Set ( &vVertRuled, curTriangle.X, curTriangle.Y, curTriangle.Z, 1.0 );
BaseCRC vertRuledCRC( (u8 *)&vVertRuled, sizeof ( Vector ) );
f32 u, v;
if ( ( Math::Abs( planeNorm.X ) - Math::Abs ( planeNorm.Y ) ) > -0.001f
&& ( Math::Abs( planeNorm.X ) - Math::Abs ( planeNorm.Z ) ) > -0.001f )//project to YZ plane
Vector4fv vDir = planeNorm & yAxis;
Vector4fv uDir = planeNorm & vDir;
Vector4fv vProjAnchorToPt = curTriangle - anchorProj;
u = vProjAnchorToPt * uDir;
v = vProjAnchorToPt * vDir;
else if ( ( Math::Abs( planeNorm.Y ) - Math::Abs ( planeNorm.X ) ) > -0.001f
&& ( Math::Abs( planeNorm.Y ) - Math::Abs ( planeNorm.Z ) ) > -0.001f )//project to XZ plane
Vector4fv vDir = planeNorm & xAxis;
else //project to XY plane
switch ( triIdx )
case 0:
u = uv0.U;
v = uv0.V;
break;
case 1:
u = uv1.U;
v = uv1.V;
break;
case 2:
u = uv2.U;
v = uv2.V;
break;
bool bHaveReplacedNormal = false;
Vector4fv vReplacedNormal;
s32 dwSmoothRes = SmoothNormal ( vertsNormalIndexMapForPlannar, vertRuledCRC.GetCRC(), planeNorm, u, v );
continue;
vReplacedNormal = m_SmoothedNormal;
bHaveReplacedNormal = true;
if ( bHaveReplacedNormal )
AddVertex ( curTriangle, vReplacedNormal, u, v );
else
AddVertex ( curTriangle, planeNorm, u, v );
Code 2:
void FuzorExportContext::OnPolymesh( PolymeshTopology ^node )
ExportElementInfo ^curElementInfo = m_CurDocumentInfo->GetCurrentElementInfo();
if ( curElementInfo == nullptr )
return;
if ( curElementInfo->m_bSkipElement )
return;
if ( m_exportOptions->m_bIncludeMeshes && !curElementInfo->m_bSkipGeometry )
ExportedMeshInfo ^pCurMesh = gcnew ExportedMeshInfo();
System::Collections::Generic::IList<Autodesk::Revit::DB: olymeshFacet^> ^pFacets = node->GetFacets();
const int dwNumFacets = pFacets->Count;
const int dwNumIndices = dwNumFacets * 3;
List<int> ^pIndices = gcnew List<int>( dwNumIndices );
for ( int i = 0; i < dwNumFacets; i++ )
PolymeshFacet ^pFacet = pFacets[i];
pIndices->Add ( pFacet->V1 );
pIndices->Add ( pFacet->V2 );
pIndices->Add ( pFacet->V3 );
IList<XYZ^> ^pPoints = node->GetPoints();
IList<XYZ^> ^pNormals = node->GetNormals();
IList<UV^> ^pUVs = node->GetUVs();
DistributionOfNormals dist = node->DistributionOfNormals;
pCurMesh->m_Points = gcnew List<Vector4fv>( dwNumIndices );
pCurMesh->m_UVs = gcnew List<UVv>( dwNumIndices );
Matrix4x4v mTransform = Command::TransformToMatrix ( m_CurDocumentInfo->m_transforms->GetCurrentTransform() );
for ( int i = 0; i < dwNumIndices; i++ )
Vector4fv vPoint ( pPoints[pIndices[i]], 1.f );
Vector4fv vTransformedPoint = mTransform * vPoint;
pCurMesh->m_Points->Add ( vTransformedPoint );
pCurMesh->m_BoundsMin = pCurMesh->m_BoundsMin.Min ( vTransformedPoint );
pCurMesh->m_BoundsMax = pCurMesh->m_BoundsMax.Max ( vTransformedPoint );
return;
return;
pCurMesh->m_Normals = gcnew List<Vector4fv>( dwNumIndices )>H>
switch ( node->DistributionOfNormals )
case DistributionOfNormals::AtEachPoint:
Vector4fv vNormal = mTransform * Vector4fv ( pNormals[pIndices[i]], 0.f );
pCurMesh->m_Normals->Add ( vNormal );
break;
case DistributionOfNormals::OnePerFace:
Vector4fv vNormal = mTransform * Vector4fv ( pNormals[0], 0.f );
break;
case DistributionOfNormals::OnEachFacet:
Vector4fv vNormal = mTransform * Vector4fv ( pNormals[i], 0.f );
break;
UVv vUV ( pUVs[pIndices[i]] );
pCurMesh->m_UVs->Add ( vUV );
ExportedFace ^pCurFace = nullptr;
if ( m_bWithinFace )
pCurFace = curElementInfo->m_pCurExportElement->m_pExportFaces->Peek();
else
pCurFace = gcnew ExportedFace();
pCurFace->m_dwMaterialId = m_dwCurrentMaterialId;
curElementInfo->m_pCurExportElement->m_pExportFaces->Push ( pCurFace );
pCurFace->m_pExportedMeshInfo = pCurMesh;
#if _DEBUG
if ( pCurMesh->m_Points->Count != pCurMesh->m_UVs->Count )
TaskDialog::Show ( "Export Error", "Point Not Equal To UV!\n" );
#endif
