Getting error while creating a door in Level 2
abdul.rafee
Message 1 of 26
abdul.rafee
I am trying to place a door on Level 2 but failed to say that cannot cut the instance of the door out of the wall.
below screenshot for you better understand
below my code
Replies (25)
Message 21 of 26
sayu94
i don't know, what are you doing. Please give me your code
Message 22 of 26
mhannonQ65N2
Try placing a door in that wall manually and use RevitLookup to look at its Location property.
Another thing you could do for testing is to change the top and bottom extents of the wall on level two so that it goes down to level one and perhaps up to level four. Then, try running your code and see if it places the door somewhere on the wall.
Also, I've used an overload of NewFamilyInstance that takes a level but not a host. With that method, the z coordinate was the offset from the level, not the total z coordinate. It's possible that the overload you're using works the same. Perhaps you could try @sayu94's suggestion of projecting your point onto the wall's LocationLine then setting its z coordinate to 0 (or the wall's offset from level 2, if it is not zero).
Message 23 of 26
abdul.rafee
sorry for the late reply I was busy with other work
below the code
public FamilyInstance CreateNewDoor(Document doc, "M_Single-Flush", "Custom Door Type - 2 M", "Level 2", XYZ xyz, Wall wwall, Application app)
// LINQ to find the window's FamilySymbol by its type name.
FamilySymbol familySymbol = (from fs in new FilteredElementCollector(doc).
OfClass(typeof(FamilySymbol)).
Cast<FamilySymbol>()
where (fs.Family.Name == fsFamilyName && fs.Name == fsName)
select fs).First();
// LINQ to find the level by its name.
Level level = (from lvl in new FilteredElementCollector(doc).
OfClass(typeof(Level)).
Cast<Level>()
where (lvl.Name == levelName)
select lvl).First();
#region Find the hosting Wall (nearst wall to the insertion point)
#endregion
//Wall wall = null;
//double proximity = (wwall.Location as LocationCurve).Curve.Distance(xyz);
//double distance = double.MaxValue;
//if (proximity < distance)
// distance = proximity;
// wall = wwall;
FilteredElementCollector collector = new FilteredElementCollector(doc);
collector.OfClass(typeof(Wall));
List<Wall> walls = collector.Cast<Wall>().Where(wl => wl.LevelId == level.Id).ToList();
Wall wall = null;
foreach (Wall w in walls)
double proximity = (w.Location as LocationCurve).Curve.Distance(xyz);
wall = w;
// Create door.
using (Transaction t = new Transaction(doc, "Create Door"))
t.Start();
if (!familySymbol.IsActive)
// Ensure the family symbol is activated.
familySymbol.Activate();
doc.Regenerate();
ViewPlan viewPlan = doc.ActiveView as ViewPlan;
Level nlevel = viewPlan.GenLevel;
XYZ levelPoint = new XYZ(xyz.X, xyz.Y, nlevel.Elevation);
//XYZ nxyz = new XYZ(xyz.X, xyz.Y, level.Elevation);
FamilyInstance door = doc.Create.NewFamilyInstance(levelPoint, familySymbol, wall, StructuralType.NonStructural);
doc.Regenerate();
// Category doorCategory = Category.GetCategory(doc, BuiltInCategory.OST_Doors);
//CreateProjectParameterFromSharedparameterAndAddValue(doc, app, "UnitName", door, "201", doorCategory);
t.Commit();
return door;
//string prompt = "The element was created!";
//TaskDialog.Show("Revit", prompt);
Message 24 of 26
abdul.rafee
Thanks, brother for your reply, if you have any code for your suggestion I will try.
Message 25 of 26
abdul.rafee
I got the solution
// adding this code will place the door any level
LocationCurve locationCurve = (LocationCurve)wall.Location;
XYZ center = locationCurve.Curve.Evaluate(0.5, true);
Many thanks for support.
Message 26 of 26
abdul.rafee
Thanks, brother for your support.
